Old 01-11-2018, 08:07 AM
Buzzland Buzzland is offline
Default RV-6 Elevator WTB
I'm searching for a left side elevator with electric trim set up
Please contact me @ five 0 one - 7 three zero - 45 one five.
TXT or CAll! Thank You1
Old 01-11-2018, 08:13 AM
kentlik's Avatar
kentlik kentlik is offline
Is it the same as -7? I have two used -7's. If they work, I will check condition.
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
Old 01-12-2018, 04:27 PM
Mrjdwalker Mrjdwalker is offline
Default RV 6 elevators for sale
Hello all, I have a set of the following for sale - all done, just need final metal trim and tips added (I have those included), have the vertical, Rudder, both elevators& trim tabs, NO horizontal though- ask 1K. Located Chandler, Az CHD
(602) 663-3092 JD Walker
Old 01-12-2018, 06:47 PM
Default Love Vans Airforce!
Thank you so much for the response. Ive been told that the earlier kit I have has a slightly different elevator than the later RV6 kit which is the same as an RV7. I would need to verify but I may have found the parts I need with Mr. Walker.
Old 01-14-2018, 09:34 AM
rv8builder2014 rv8builder2014 is offline
Default Elevator replacement
If you need a replacement elevator I would be able to build one for you. I assume that this was a non punched kit? If so any other elevator than the one originally built with the kit will most likely not fit. If you want to talk directly give me a call at 541-844-6120. Hope that I can help.
