Old 01-12-2018, 09:02 AM
Sam Buchanan's Avatar
been here awhile
A fine lift, but can't be stiff enough to confidently allow crawling around back in the tail. Remember, there is a big difference between stiffness and strength.
Structurally, the upright members have no significant base width, so they can flex on the base structure. The base structure itself has the wheels out on the ends of horizontal members...wavy wands in the stiffness context. And lateral stiffness of the carriage depends on the bending stiffness of the long rails.
Remember, the original product was designed with shipping in mind. If you're going to build your own, a simple redesign could improve its utility. At a minimum, substitute 1" x 2" 16ga for the 1x1 base members and carriage rails. I'd use 3 x 1-1/2 if I could get it in a light gauge, with the forward wheels between tabs on the 1-1/2 centerline. The single 1x1 rear upright (the one with the winch) would become two 1x1 uprights, pyramid fashion, extending to a point near the rear wheels. They're only loaded in tension/compression, so they only need a wider base. Space the carriage rails farther apart, so the arm with the rollers can be a length of rectangular tube rather than the 1/4 x 1-1/4 bar.
Dan, I two was concerned about side-to-side stiffness and plan to beef up the design for my version with a fourth leg similar to what you described.
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Old 01-12-2018, 09:13 AM
Mel's Avatar
Mel Mel is offline
I love my "tail-mate" but I don't rely on it for strength when crawling back into the tailcone. I lift the tail with the tail-mate and then place a sawhorse under the forward end of the tail spring.
A&P/EAA Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 01-12-2018, 09:17 AM
Ironflight's Avatar
VAF Moderator / Line Boy
I'm with Mel (and Dan, really....) - the TailMate is for lifting, a padded saw-horse is used if we're goign to get in the airplane. I don't crawl under a car that's just on a jack (without jack stands) either!
With an older (and aging...) spine, I won't let my TailMate go - too much twisting to lift RV tails by hand.
I'll have to take a picture of the MONSTER TailMate knock-off our former partner built for our Tundra. I could lift a small car with it......
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 01-12-2018, 03:09 PM
Wolfpack3 Wolfpack3 is offline
Default I designed the Tail-Mate!
I still have the original drawings I made when I designed the Tailmate.
My first opportunity to sell them was when I purchased a 10x10 space at SnF back in 2002. Sat there all week and didn't sell ONE unit! All I got was people taking pictures and saying they could build their own for less money. Then they were $179.00. All I said was...go right ahead...have at it. Let me know when you exceed $179 assuming you work for more than a dollar an hour. Everyone around where I live who had an experimental wanted one and was delighted to spend the money for one. My how times have changed. I am so enjoying this thread. For those who purchased one...Thanks for the support. For those that took pictures at SNF...How is the tailmate build coming along?
And lastly...NO! The TailMate WAS NOT designed to be stable and strong enough to crawl back in the the tail...Mel is right!
Old 01-12-2018, 03:28 PM
goatflieg's Avatar
Great response... and thanks for chiming in. I joined the builder pool too late to purchase an original Tailmate; if you ever decide to market another, add me to your mailing list.
Martin J Filiatrault
Clarkston, MI
N657AR reserved
Builder websites:
YouTube Channel:
Dues paid for 2019... extra payment included for psychological therapeutic services rendered.
_______________________
Old 01-12-2018, 03:37 PM
been here awhile
It is a clever design, my compliments.
Just for clarification....is the Tail-Mate still in production and available to purchase? If so, I would be reluctant to build my own. If not........game on. I work for a lot less than a dollar an hour.
Sam Buchanan
1999 RV-6
Old 01-12-2018, 05:03 PM
Larco Larco is offline
Originally Posted by CanyonDweller View Post
I built one of these, without plans, last month. I had seen pictures on VAF years ago, but when I searched for them they were all gone. It took me about three days in the shop and going to the airport to modify an redo to get it right. I’m pleased with how well it works. Larry (Larco) seems to have built his in less time than it takes me to get the welder ready. Excellent job Larry.:
Oh No, Ha, I was thanking Bruce for sending out plans which he had offered to do sometime ago, It was time consuming and fun, did take some extra time to modify for the fairing as well, a lot more than 3 days for sure.:-) The picture was shown as encouragement for others too. And to Wolfpack3, Thank you! Someone has to only build one to appreciate the design and effort you put into this
Old 01-13-2018, 04:16 PM
rv8ch rv8ch is offline
Default trailer winch?
Is that a trailer winch on there?
Mickey Coggins
http://rv8.ch
Old 01-14-2018, 12:13 PM
dsmith1055's Avatar
dsmith1055 dsmith1055 is offline
Default Lifting the tail
I bought a Harbor Freight Lift table for around $45.00. It lifts the tail of my RV and several other planes nicely. It also allows me to install my bottom cowling without assistance and is useful in many other ways.
Dwight Smith CFI
Flight Advisor - Tech Counselor
Old 01-14-2018, 01:41 PM
Yes, from Harbor freight
