Old 01-04-2018, 06:57 AM
1bigdog 1bigdog is offline
Default Left turns only?
I mocked up some foam to simulate seat height on my RV-9A.
In sitting left seat I noticed the control stick was biased toward the right. Very little room to roll right but lots of room on the left.
This spacing is controlled by the factory holes in the 904 bulkhead web and the weldment fits perfectly. So this seems like a bit of tubular weldment (maybe about an 1") is missing to center it.
The holes for the crotch straps, rudder pedals and seat are all centered, it's just the left stick's base weldment.
I know someone with an RV-7 who noticed the same as he is at about the same place in his build. Anyone gone to VANS to replace the weldment?
Thanks.
Michael B.
C-FWMB (reserved)
College Fund Contributor
Old 01-04-2018, 07:23 AM
Rupester Rupester is offline
I recall substantial adjustment and multiple assembly points of the stick-control assembly that affected L-R bias on the sticks. My pilot stick is perfectly vertical, but I ran out patience in the assemble-check-disassemble-adjust process and my copilot stick is a few degrees off of vertical.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 01-04-2018, 09:21 AM
Default not adjustable !
Hi Terry
I'm not so much talking about the adjustments that can be done using the hex rod. I'm referring to the base of the left stick weldment being too far to the right, so the stick is sitting too close to the right leg when vertical. This appears to need an offset welded in. Everything fits perfectly. The right stick seems centered correctly.
Cheers.
Michael B.
C-FWMB (reserved)
Old 01-04-2018, 09:36 AM
RVbySDI's Avatar
RVbySDI RVbySDI is online now
A little clarity would help my mental picture of what you are referring. Yes, a picture is worth a thousand words. I will add to that word count with my questions.
Is the bias you are referring to talking about the distance from the seat cushion to the side of the stick? Or, the hole through the floor pan as it relates to the side of the stick? Or, are you referring to the fact that the stick is actually leaning to the right when attached to the push pull rod weldment below the seat pan?
So, my thoughts are leaning toward the last question. In which case that would be a matter of adjusting the push pull rod attachments to the stick and to the aileron bell crank until you get the stick in the vertical position desired at the same time the ailerons are in their correct neutral position.
Any pictures of your situation would go a long way to giving me the correct mental picture of what you are facing.
RVBYSDI
Steve
RV9A
Live Long And Prosper! 🖖🏻
Old 01-04-2018, 10:40 AM
Ralph Inkster Ralph Inkster is offline
Just looked at one of the airframes in my shop, I note the control stick is positioned a little inboard than the center line between the seat position and pedals by design. This is to make more room for your left leg as the vertical side skin bulkhead is thicker there.
Is the spacing similar for the right control stick on your project? Also is the elevator control lever positioned in the center of the tunnel? This would confirm the F633 brackets were bolted on in the correct positions.
Ralph
Maintain lots, upgraded & repaired some, modified more, rebuild a few, & built 4 of 'em
Old 01-04-2018, 01:47 PM
Default everything where it should be.
Gents,
The 633 is exactly where it should be. The holes are predetermined by the factory drilled holes in the 904 bulkhead. All fits perfectly.
I didn't sit in the right seat yet but when I eyeball it everything appears perfectly aligned on the right, but offset on the left seat . I did try to shift my body inboard but then I'm mis-aligned to the rudder pedals.
To make things more clear (I'll try to take a picture better representing the issue tonight), when seated correct for the rudder pedals and centered to everything on the left seat, stick is vertical, the stick is almost at my right leg; whereas there is plenty of separation to my left leg. The base weldment of the vertical stick appears to need about an inch or more of spacer to set the base of the stick in the centre. It's not an adjustment from what I can see. The location is set by the position of the 633's and size of the horizontal weldment and everything moves perfectly freely, no binding at all.
Thanks.
Michael B.
C-FWMB (reserved)
Old 01-04-2018, 02:54 PM
jfogarty jfogarty is offline
Can't wait to see a picture!
Jim Fogarty
RV-9A Flying
Old 01-04-2018, 08:14 PM
gasman gasman is offline
This issue is also evident in the RV6. So if Van's carried it over to the 7, there must be a reason. Just gotta get over it and build on.
VAF #897
2017 =VAF= Dues PAID
Old 01-05-2018, 06:15 AM
BillL BillL is offline
Default In my RV7 . . .
My sticks are vertical as well. When using the fixture tool for the ailerons and setting the length of the bell crank-to-stick pushrods, a little adjustment (shortening) rendered the sticks vertical. With carpet and seats in place the left-right aileron stops are both usable.
Bill
Op Lims in hand 12-7-17
1st Flight 1-27-18
2017 Dues Paid
Old 01-05-2018, 08:11 AM
Default building on ...
Hi Gasman
I tend to agree because regardless there is nothing I could see that could be done. I went into the "hangar" (otherwise known as the left side of my garage) last night. At -20c it wasn't a good time to be checking this but I did want to check the right seat as well. Some of this is getting used to a position that is foreign on 5" of pink foam. Some of it is over analysing because I'm in the midst of confirming rudder, seating, stick positions and things just don't line up perfectly. I'll look at this more closely and take measurements on the weekend to make sense of it. I'd like to get into the DA20 as well to see how this differs. I might be able to check that on Saturday.
Thanks.
Michael B.
C-FWMB (reserved)
