Old 03-08-2018, 03:17 PM
airguy's Avatar
airguy airguy is offline
Originally Posted by cojaken View Post
I thought the O360 B1B only produces 168hp.
If this is correct, would the folks concerned about too much horsepower for the 9A still be concerned?
Probably. Some folks put way too much emphasis on an arbitrary limit that was set in stone and proclaimed to be "The Limit."
Yes, there are reasons to limit horsepower on any aircraft design. No, those limits are not likely to be sharp-edged leading to a "you will die" scenario if you approach 100.1% of that limit. Yes, there will always be people creeping across that line a little, just like we drive too fast on the highways. And yes, there will always be people wagging fingers at those who do it.
Greg Niehues - PPSEL, IFR, Repairman Cert.
Garden City, TX VAF 2019 dues paid
N16GN flying 360hrs and counting! Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
Old 03-08-2018, 03:59 PM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
Originally Posted by N941WR View Post
Yes and no.
When I bought my ECi kit engine the difference between the 320 and 360 was $500 and 20 pounds. Since i knew I was going to run Catto, I'm still lighter than a 320 with a metal fixed pitch prop.
With an overhaul, all bets are off, until you open it up and know what you have.
Originally Posted by RV8JD View Post
Something to consider. Last page for RV-9A:
https://www.vansaircraft.com/pdf/Nos...ice_letter.pdf
Seems to me that everyone should build taildraggers!
Doug, it all depends on what prop you want to put on your -360. As I mentioned above, my O-360 and Catto FP prop is lighter than an O-320 with a metal FP prop. If I put composite CS prop on it, I would still be lighter than a 320 with a metal CS prop, which is approved.
As you build, you once again have to go through the Q&A process to figure out which configuration, options, etc. you want in your plane.
As you pointed out, your -9A with a 160 hp (I)O-320 was a good performer. There is absolutely nothing wrong with that engine.
If weight is a concern but you still want the HP a 360 provides you should not discount this engine:
http://www.continentalmotors.aero/ti...ines/x340.aspx
I have 592 hours on the ECI IO-340. I would not want any other engine on my 9A. Weight on the nose gear was an important factor. So, running the IO-340 with a 3-blade Cato is ideal. The engine turns out to be 8 lbs lighter than a 360 and still has 180 HP. I know the traditional 320 or 360 engines are pretty much the norm for RVs but the 9 does very very well with the IO-340. At least my 9A does! Anyone contemplating what engine to use in the 9 should give it consideration.
Live Long and Prosper!
RVBYSDI
Steve
RV9A
https://rvwings.com
Live Long And Prosper! 🖖🏻
Old 03-08-2018, 06:35 PM
N941WR's Avatar
N941WR N941WR is offline
It is kind of funny that no one even raises an eyebrow when larger than recommended engines are installed in RV-4, -6, -7, and -8's.
I guess only the -9 will fall out of the sky when over engined.
One thing to keep in mind, and we in the RV world often forget this. The O-320 150 hp Lycoming was designed to lift a four place engine. In our little planes, they are a great choice, if you keep everything light.
When I had the O-290 of all of 135 hp in my RV, it was a GREAT combination. When I would travel with the local RV gang for a couple of hundred mile trip, I would take off first and when I would enter the pattern, the last airplane ahead of me would be just touching down.
The bigger engines really only gain you in ROC and not so much in cruise speed. Even then, 1400 FPM is nothing to shack a stick at.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 03-08-2018, 07:50 PM
Doug Rohrer Doug Rohrer is offline
Lots of good info on this and related threads. After shopping for both O-320 and O-360 used engines, I found a deal on an O-320 that was a fresh rebuild on the lower end with no cylinders, which was what I was looking for. I just received my new Lycoming cylinders and will start the assembly process as time permits. The money saved compared to a new engine will go a long way towards the panel I want. Thanks for all the responses. I am sure we all learned something about engine choices in this thread.
Doug Rohrer
Bowling Green, KY
Old 03-09-2018, 08:58 AM
airguy's Avatar
That's pretty much it in a nutshell, yes. But I sure do enjoy holding 2000+ off the runway!
Somebody asked me the other day how long I hold that climb rate coming off the runway. My answer was "Long enough that nobody thinks I did it by accident."
