Old 01-02-2018, 01:12 PM
Junk8 Junk8 is offline
Default EMAG MAP HOOK-UP
I have the YIO-390EXP10 Lycoming engine installed. I ordered it with the EMAG already mounted. Anyone know where the MAP line gets hooked up? I have a Dynon MAP sensor on the firewall which is connected to the side of the engine. Does the EMAG line get "T"d into this line? Anyone else have this configuration?
Old 01-02-2018, 01:21 PM
Toobuilder's Avatar
Yes, you can T into the MAP line.
Michael Robinson
______________
RV-8 - Flying
Old 01-02-2018, 07:01 PM
N941WR's Avatar
N941WR N941WR is offline
Mike is right, T into the MAP line going to your EFIS MAP sensor; however, you need to add a restrictor in the line before the "T".
Perform a search on "Manifold line restrictor", there are a LOT of options,
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 01-04-2018, 06:02 PM
jeffw@sc47's Avatar
jeffw@sc47 jeffw@sc47 is offline
Tom at TS Flightlines knows exactly what to do. Made a double T for me for two Pmags.
www.tsflightlines.com
Jeff Warren
Simpsonville, SC (SC47 - 10nm NW Triple Tree, SC00)
1946 Bellanca Cruisair 14-13-2 (72 YRS OLD 8/15/18)
RV14A (N14ZT), Ser#140195
Start 10/11/14
IO-390 Lyc Tbolt / CS Hartzell
Well into the panel and its stuff now
Dues paid 12/1/17 (USArmy 2/67-2/70)
www.mykitlog.com/jeffw@sc47
Old 01-05-2018, 11:04 AM
morganjp morganjp is offline
I run a single Pmag on my O360 now but When I was running dual P mags I had a separate map line for each unit connected to the engine ports and that worked fine.
John Morgan
Atlanta, GA KPDK
N613SC
RV6A -SMILIN 1
Old 01-05-2018, 01:13 PM
N941WR's Avatar
What engine ports are you talking about?
Bill R.
SC86 - Easley, SC
Old 01-05-2018, 03:11 PM
Primer ports for cylinder 3 or 4
John Morgan
Atlanta, GA KPDK
N613SC
RV6A -SMILIN 1
Old 01-05-2018, 04:25 PM
N941WR's Avatar
Thanks, I thought I might have missed something.
Be sure to put a restrictor in each line. Otherwise your P-mag's timing will bounce all over the place and will not be in time with each other. This is especially important since you have two different MAP sources.
The reason for the bouncing MAP readings w/o a restrictor is that when the intake valve closes it creates a high intensity, short duration positive pulse in the MAP line. The restrictor smooths these out.
Bill R.
SC86 - Easley, SC
Old 01-05-2018, 06:22 PM
Aircraft Specialty Aircraft Specialty is offline
We currently have the dimensions for a complete firewall forward fuel, oil, and PMAG hose setup with a dual PMAG installation for the RV-14. We are compiling a bit more data and pictures and will be releasing it officially in a few weeks. If anyone is ready before then or has any questions, we can build the packages but do not yet have them available on our website for online ordering.
Have a great weekend and happy building!
www.aircraftspecialty.com
Please email us at aircraftspecialty@gmail.com with any questions.
Your Source for Custom CNC parts, CNC cut instrument panels and labeling, Teflon fuel/oil hoses, Headsets, and many other items for Experimental Aircraft.
Old 01-06-2018, 07:13 AM
Nova RV Nova RV is offline
I have the hoses from Steve and Aircraft Specialty for my 14A and dual P-Mags and everything fits perfectly and is a nice upgrade from the stock hoses.
Chris Moon
Leesburg, VA
RV-14A kit # 140243
VAF 2017 and 2018 paid
www.mykitlog.com/chrismoon/
