Old 01-02-2018, 01:04 AM
Sqrfrk Sqrfrk is offline
Default Cargo Space for a Mountain Bike?
I'm looking at the cargo space dimensions on paper and it seems like it can fit a frame and wheels in pieces - does this hold up practically? Would I be able to break down two downhill bikes and stuff it in the cargo hold?
Old 01-02-2018, 05:22 AM
MED MED is offline
The baggage area is pretty large. I think the bigger question would be whether you want to shove bicycle parts across the top of your beautiful seats to get them into the baggage area.
MED
140236
N435MD reserved
Old 01-02-2018, 08:46 AM
mikerkba mikerkba is offline
Default Bicycle case
Many of the folding bike manufacturers offer a case, which would help avoid snagging and scratching. Or you could make your own.
I'm looking at a folding Montague (or equivalent "full wheel size) bike, intending for car and RV8 (with rear seat removed) transport. I think 2 would fit back there.
Mike Coster
BUILDER: N92MB RV7A (A/W 3/2009) - Sold
ADOPTED/reworking: N4032Q RV8A (8/2017)
KELY/Ely, NV
Old 01-02-2018, 08:51 AM
Ron B. Ron B. is offline
Seats come out easy enough if that was your only problem.
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 01-04-2018, 06:59 AM
Jared_Solomon's Avatar
Jared_Solomon Jared_Solomon is offline
Default Doable, maybe not practical
The RV-14's baggage space is large. With that being said I believe the challenge may be getting the bike's frame between the seat back cross-member and the roll bar. You'd probably have to turn the frame on it side to pass through and then rotate it back to right side up. Not sure if you'd have to remove the fork as well. I doubt you'd be able to get a second bike back there, due to the manipulation required as described above. Possibly if you remove the fork/handle bars. Probably one of those things you'd have to try. Like others have eluded too, if you plan to transport a mountain bike regularly, the wear and tear level on your plane may be high.
Jared Solomon
A&P, EAA Technical Counselor
Powder Springs, GA
2018 Dues Paid
RV-14A (N214WJ) - Flying since Sept 2017
RV-7A (N211WJ) Flying since 2009 (SOLD)
RV-7A (N132RD) bought flying 2014 (SOLD)
KPUJ (Silver Comet Field)
Youtube channel: http://www.youtube.com/jmsolomon2000
RV-14 Build Log: http://rv14.jaredsolomon.net
Old 01-04-2018, 08:38 AM
EXTAAFLY EXTAAFLY is offline
Default Not two. . .
I am an avid Mountain Biker. I was hoping to get two 29r trail bikes and gear in the back of the -14. Not likely, without a complete tear down of the bikes, and then it's only gonna fit 1 and gear. A long travel DH bike would definitely be a challenge, with the fork alone. However, I have only looked at the cargo space on the demo and a couple of in process airplanes. Haven't tried to do it yet.
I think the technique will be for the front brake to come off, fork to come off, and both wheels to come off. Place a travel bag in the cargo compartment and put the parts in the bag. Then stack gear on top. My trail bike comes in at around 28 lbs, Niner RIP 9 RDO with Carbon everything, 160mm travel up front. So, two would be roughly 60 lbs. bags and tools.
Now the questions that will probably present. More tools? Do I bring a work stand? What about room for additional gear? Multi-day trip? I think with two DH bikes, you're gonna chew up a 100 lbs quickly. You guys tend to wear a lot of protective gear and big helmets.
Honestly, the BearHawk with the cavernous cargo space and optional side door is probably the best way to go for this type of use. If I thought I'd be doing a lot of fly and bike stuff. . . I'd take a serious look at that machine. Plus it has the ability to get you right to a trail head in certain parts of the country.
Jason
RV14A #140419
N141RX Reserved
Tail Cone & Empennage - Started 11/6/2017 Done'ish 11/18/17 Synergy Assisted
Quick Build Wing and Fuselage Delivered 3/5/2018
Fuselage - Prepping for Paint
Wings - Later
Tool Acquisition - Ongoing (Is this ever done?)
5/13/18 Donated and leaving this here, so I can remember to do it next year.
Old 01-04-2018, 01:23 PM
Well, the DH was more of a worst case - I have two Enduro bikes but the weight seems similar.
Murphy was going to release the Radical (seems to have adapted the Cessna bike rack from the pilot in New Zealand), but they're not being very forthcoming with performance numbers.
In any case, the point is moot since I'm already well into an RV-14 build. I'm just wondering if a combination of removing the seats and tetris'ing the frame/fork/wheels would be feasible to a 700 mile flight to KCNY.
Old 01-04-2018, 03:15 PM
I hoping to be able to do the same thing when things get done. Just going to have to wait and see. Right now, I'm just not that optimistic about fitting two bikes back there. I hope it works because I'd love to be able to jump in and be up to Bend in a few hours or over to Moab.
Jason
RV14A #140419
N141RX Reserved
Wings - Later
Old 01-04-2018, 04:12 PM
Ironflight's Avatar
VAF Moderator / Line Boy
I'm currently building a pair of racks based on the Murphy plans for our Dream Tundra. Racks are done and we've flight tested them bare with no issues. Hung bikes on them and weren't satisfied with their stability (side to side) so I'm building some stabilizer struts that will attach it the seat post, then we'll give them a try.
I flew the Radical with and without bikes and there was very little difference in speed, and power off descents showed surprisingly little difference as well. High wing strutted airplane's have plenty of drag already, so the increment with the bikes isn't that much. I don't think I'll want to fly more than 90-100 knots with them anyway.
None of this is aplicable to the RV's of course - but it's a whole lot easier than reducing the bike to kit form to fit into the baggage compartment.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 01-04-2018, 07:46 PM
Jim P's Avatar
Jim P Jim P is offline
Default Mt. Bikes
So I have a -7 with a tipper and also ride a Specialized FSR Stumpy 6F and I've gotten it in the airplane for a test. You won't get two bikes in a -7.
1) Remove both wheels and put the plugs in the brake calipers to prevent piston expansion and brake fluid leakage.
2) Remove the handlebars at the stem, but don't disconnect any of the cables. Handlebar should lay along the longitudinal axis of the bike just fine and the fork can remain on the bike.
3) Lower seat or remove it
4) If needed, remove left pedal
5) Remove co-pilot bottom seat cushion and put a towel or blanket over the seat back.
6) Place the bike in the seat, with the fork over the seatback so the aft frame points to the front of the aircraft, the frame should fit nicely where legs normally go. Be careful if you've removed the stem, so the fork doesn't come out.
7) Strap it down.
8) Put wheels in the baggage compartment.
Here's a link to my Rockhopper 29r in the seat to give an idea: https://1drv.ms/i/s!Al5IppCB40wPgux4MKBnjPXAjQVjhQ
Jim Piavis
RV-7 (Flying!)
http://adap.com/rv7
Redmond, WA
