Old 12-28-2017, 12:35 PM
findane findane is offline
Default Throttle/mixture cables
The standard Van's mixture and throttle cables for 9A aren't long enough. Aircraft Spruce (ACS Cables) has a lead time for 4 to 6 weeks for custom cables. Does anyone know where else to get custom length cables made.
Dues paid 2018
Old 12-28-2017, 12:46 PM
Lynnv Lynnv is offline
Default Cables
Try McFarlane Aviation. They can make custom cables.
Old 12-28-2017, 12:55 PM
MS19087's Avatar
MS19087 MS19087 is offline
Default Vans makes several lengths
I installed an io-320. Standard -9 cables were too short. I measured and found vans had cables that worked. If I recall they make have been cable used on RV10 installs.
RV-9A; IO-320 w/ Whirlwind WW-151
(Flying since June 2011)
2018 =VAF= donor
Old 12-28-2017, 01:39 PM
How much too short? If under 6", take a look at these.
ACS has extensions for the inner rod, used them when I changed from updraft to ram air for my FI servo. http://www.aircraftspruce.com/catalo...clickkey=13278
Old 12-28-2017, 01:44 PM
koupster's Avatar
koupster koupster is offline
What length cables do you need. I may have what you need.
Cheers, David
Old 12-28-2017, 01:47 PM
N941WR's Avatar
N941WR N941WR is offline
It really depends on which sump you have on your engine.
Some place the carb forward, some in the middle, and some towards the aft end.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 12-28-2017, 02:12 PM
Default Cables
I have a Superior IO320 with Airflow Performance fuel controller on a horizontal cold sump. I had to fabricate a custom bracket and needed to add 9 inches. The extension are too short.
After speaking with ACS cable and Aircraft Spruce, Van's cables have a 2.25" or 2.5" stroke which are non standard.
Dues paid 2018
Old 12-28-2017, 02:17 PM
N941WR's Avatar
You should have just gone with a center mounted throttle quadrant from DJM, like I did. Much easier to install and fit a cable to.
And so much nicer to fly with than a Cessna style throttle.
Bill R.
SC86 - Easley, SC
