Old 12-27-2017, 01:11 PM
n74846 n74846 is offline
Default Skyview 1000 Software Upgrade; Which One?
It's time to upgrade my Skyview from 14.x to 15 and there are two different software versions available on the Van's website. For the Skyview D-1000 classic, do I use the (T) version or the HDX? Thanks!
Steve at BCT
Flying a built ELSA
Old 12-27-2017, 01:17 PM
Raymo's Avatar
Raymo Raymo is offline
For Skyview 1000T or non-touch, you would go with the non-HDX upgrade. HDX is their newer product that started life with version 15 last year.
If your system is installed in an SLSA, you may be required to run what the MFG has approved.
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
Old 12-27-2017, 01:47 PM
RVTrumpet's Avatar
RVTrumpet RVTrumpet is offline
The "12-SVD1000(T)" is for touch and non-touch D1000. Use that one.
Have you done the software update process before? If not, follow the README and you should have no troubles.
A couple RV-12s
Building 8A
NOTE: The information, ideas, and opinions presented in this post are my own and not those of my employer. Build, test, and fly at your own risk.
Old 12-27-2017, 01:51 PM
Mel's Avatar
Mel Mel is offline
Originally Posted by Raymo View Post
If your system is installed in an ELSA, you may be required to run what the MFG has approved.
Perhaps you meant SLSA. For ELSA, you don't have to follow MFG approval.
A&P/EAA Tech Counselor/Flight Advisor
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 12-27-2017, 02:08 PM
Raymo's Avatar
Yes, thanks! Post updated
Ray
NSDQ
Old 12-27-2017, 08:51 PM
Thanks to all for the clarification.
Steve at BCT
Flying a built ELSA
