Old 12-26-2017, 03:42 PM
Default Drilling out CCR264SS-3-2 rivets
RV12 Section 21. Page 21IS/U-5.
Unbeknownst to me, the nutplate had fallen off as I pulled the CCR264SS-3-2 rivets.
These are those hollow rivets (once pulled) that are used for nutplates and they don't seem to drill out as easily (if it at all) as regular CherryMax rivets, plus they're steel . And because they're small and the hole is mostly hollow, they spin like a sonofofagun.
Who's done this before and can recommend a procedure?
Bob Collins
St. Paul, MN.
Almost ready to start the RV-12iS finishing kit. 480 hours in.
Builder log
Old 12-26-2017, 03:44 PM
bkervaski's Avatar
bkervaski bkervaski is online now
This ..
http://www.aircraftspruce.com/catalo...driv-03368.php
Works great!
Edit: Not sure why someone gave it a 2-star review, it has different sizes for different rivets and I have never scarred anything using it correctly.
Progress: Flying!
Old 12-26-2017, 03:53 PM
Got a pair of flush cutting 'dykes' (diagonal wire cutters)? If you've got a pair that are old and no longer great for wire cutting, you can use them as a combo gripper and wedge to hold the head while drilling. Won't make it easier to drill, but will help prevent spinning. The jaws will either grab the head, or wedge between the head and the material (bulkhead, skin, etc) which will increase friction to reduce spinning. Go slow with the drill & use a sharp (and sacrificial, in the case of stainless) bit.
Old 12-26-2017, 08:20 PM
rongawer rongawer is offline
I second the blind rivet removal tool. Its made by ATS and works very well. The tool head bites into the rivet head and holds the rivet from spinning while you drill out the center. Id give it five stars.
Ron Gawer
- RV10, N1530G (reserved). Empennage in progress.
- RV12, N975G, "The Commuter"
Old 12-27-2017, 12:10 AM
az_gila's Avatar
az_gila az_gila is offline
Question
Originally Posted by rongawer View Post
I second the blind rivet removal tool. It’s made by ATS and works very well. The tool head bites into the rivet head and holds the rivet from spinning while you drill out the center. I’d give it five stars.
How well does it center on a flush countersunk rivet?
The Spruce description says - The serrated nosepiece fits over any button head, round head, or universal head rivet
No mention of flush rivets.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 12-27-2017, 05:37 AM
mike newall's Avatar
Or.....
Just launch what you have left into the trash and use CCC-32's.
We stopped using them them very early in the build.
Donated in 2018
Old 12-27-2017, 08:13 AM
bkervaski's Avatar
It works the same. On flush rivets I start the hole with a tiny bit just to make sure it starts centered. On dome rivets a centering hole isn't necessary. Really does work well, you just have to make sure you use the appropriate sized head (most common ones are included) so the "teeth" only grab the rivet and not the surrounding skin.
Progress: Flying!
Old 12-27-2017, 10:14 AM
As noted, it does work on flush rivets. The serrated nose piece bites in well, just place it firmly before you start the drill. The more expensive tool that ACS sells comes with the serrated tips; I’m not sure about the less expensive one.
It makes easy work of removing rivets; while solid flush rivets do come with a drill punch, I still use this tool to ensure the bit stays centered and no more elongated holes.
Ron Gawer
Old 12-28-2017, 07:57 PM
To conclude, it came out fine with the modified side cutters and a new drill bit.
Bob Collins
St. Paul, MN.
Builder log
