Old 12-25-2017, 12:35 PM
Boat Boat is offline
Default Full flaps flaperons stiff
The last couple of flights I've noticed the flaperons become stiff to operate when I pull on full flaps.
Anyone else have this problem or know what might be causing it?
Old 12-25-2017, 12:50 PM
rongawer rongawer is offline
I have not experienced this, however, I recommend pulling all of the tunnel covers and inspecting the the system before you fly again. If there isnít anything that has obviously worn or is binding, than try spraying all of the pivots and rod ends with LPS-2, which is a great heavy lubricant.
Ron Gawer
- RV10, N1530G (reserved). Empennage in progress.
- RV12, N975G, "The Commuter"
Old 12-25-2017, 01:08 PM
DHeal DHeal is offline
Also make sure that appropriate Bearing Bracket Brace SB (http://www.vansaircraft.com/pdf/sb14-12-06.pdf) has been complied with.
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 710+ hours (as of Dec 2018)!
VAF donation through June 2019.
Old 12-25-2017, 02:40 PM
Rrhsch Rrhsch is offline
Make sure the nuts on the control stick push rods that connect to the flaperon mixer bell-crank are not rubbing on the F-00049 wire cover. This would only be noticed when full flaps are used.
Old 12-25-2017, 05:15 PM
JBPILOT JBPILOT is offline
Default Just a thought - -
If you are at 80kts, they will be stiff until you get down to say 65 kts. They should move easier as you slow down.
John Bender
Flying RV-12 - Serial #120036
Paid in May ( 5-4-18 )
Old 12-25-2017, 10:15 PM
greghughespdx greghughespdx is offline
If it's stiff on the ground, or if the feel has changed for you, take it apart and look at it. Not worth the risks that could potentially be involved, and pretty easy to inspect the assembly.
Van's Aircraft - Director, Community/Media
Van's web site | Instagram | Facebook
Opinions, information and comments posted by me are my own unless stated otherwise. They do not represent direction/opinions of my employer.
Building RV-8A since Sept 2014 (N88VX reserved)
Dual AFS 5600, Avidyne IFD 440, Whirlwind 74RV, Superior XPIO-360
VAF build thread - Flickr photo album - Project Facebook page
Flying spam can, helped build/fly a few RV-12s and some other RVs
Hillsboro, OR (EAA 105)
Old 12-25-2017, 10:22 PM
Jetguy's Avatar
Jetguy Jetguy is offline
I agree with John. Check your ailerons on the ground with the flaps down. If they move smoothly then everything is fine. The ailerons normally are a little harder to move when you put the flaps down due to airflow across them.
John
RV12 N1212K
Flying Since June 2010
1020 Hours as of 9/30/2017
Johnrv12@icloud.com
RV14 Wing, arrived and building at Rdog's new Hanger at 16X
S/N 140014
Old 12-26-2017, 07:25 AM
dbhill916 dbhill916 is offline
I discovered that if I put the flap lever all the way down, below the "0į" stop, the ailerons become very, very sensitive and the plane feels surprisingly squirrelly in roll. I was quite surprised at how much of a control feel change is generated by a relatively small deflection into "reflex flap" position.
Like the other commenters suggested, if it's different on the ground then make sure everything is OK mechanically. On the other hand, if it's only during flight, then it may be just aerodynamic.
David B. Hill
N76012
RV-12 #0760
http://n76012.blogspot.com
Dues paid through 6-2019
Old 12-27-2017, 11:33 AM
Top Cat Top Cat is offline
On the ground, when doing the control check, I do it with flaps at each position not just once before takeoff.
Old 01-29-2018, 01:26 PM
Smile
After checking "everything", it appears that the additional stick pressure is simply aerodynamic - from having full flaps at 80 knots and beginning a turn to base. The pressure is virtually gone by touchdown speeds.
