Old 12-22-2017, 06:49 AM
acropilot acropilot is offline
Default Icom A210 squelch
My A210 squelch stays open. Iíve heard that this is a recurring problem with A210
Can anyone with experience tell me how to best resolve this issue. Can it repaired permanently.
Does the 220 have the same problem.
Darwin Jones
RV-4
One Design, mustang II, Pitts S1
Old 12-22-2017, 07:23 AM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
Originally Posted by acropilot View Post
My A210 squelch stays open. I’ve heard that this is a recurring problem with A210
I had the same problem. If I set the squelch all the way up then I would miss a lot of radio calls. The only thing that fixed the problem was returning the radio to iCom and they "fixed" it under warranty.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
www.PuertoRicoFlyer.com
Old 12-22-2017, 09:34 AM
snopercod's Avatar
Hi Darwin. On my recent cross-country trip, when I got out into the sparsely-populated center of the Country, the squelch stayed open on my A210. When I got back to civilization, it fixed itself. I don't know whether I have an intermittent problem or whether the lack of radio signals in flyover country had something to do with it.
(2018 dues paid)
Old 12-22-2017, 09:48 PM
bullojm1's Avatar
bullojm1 bullojm1 is offline
I really wanted to like the A210, and fought with its inadequacy from 2010 until 2017. Best move I made was upgrading to a Garmin GTR200. No looking back, I don't miss that ICOM radio and my struggles with is one iota. Look up John Stark at Stark Avionics. Best prices in town by a longshot.
Mike Bullock
RV-7, Flying!
http://www.rvplane.com
EAA Technical Counselor
Old 12-23-2017, 12:14 AM
tim2542 tim2542 is offline
Try it on the ground with all the other boxes turned off, then fire them up one by one and see if one of them is causing the squelch to open. Some of these boxes are rather noisy, my GRT EFIS displays would open the squelch on my 210. Icom turn the sensitivity down a bit and that fixed it. I like the radio ok, no other problems with it.
Old 12-23-2017, 12:33 PM
I done the trials with different components off and on no change. However after fiddling with the ribbon cable it started working again. However, the radio did the same thing about a month ago, started working for no apparent reason.
After the holidays Iím calling Icom and one of the authorized repair stations for a plan on the best course to resolve this issue. Just hope itís not to expensive and the it truly gets resolved. Some folks have no had much luck with repairs and others have
I may very well end up with a new radio
Darwin Jones
RV-4
Old 01-11-2018, 03:32 PM
I’ve sent off the A210 for repairs for the open squelch. The problem is intermittent but was getting worse, staying open for longer periods.
Will wait now and report results.
Darwin Jones
RV-4
Old 01-11-2018, 07:00 PM
N941WR's Avatar
N941WR N941WR is offline
Iíve sent off the A210 for repairs for the open squelch. The problem is intermittent but was getting worse, staying open for longer periods.
Same thing here. I had to send mine in.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 01-11-2018, 07:28 PM
snopercod's Avatar
Default Inquiring minds want to know
Please let us know what the fix was, if they tell you.
(2018 dues paid)
Old 01-11-2018, 09:34 PM
Blain's Avatar
Blain Blain is offline
I had open squelch when the intercom was on. I fly alone so turning the intercom off solved the problem. Seems to be a VOX issue.
Blain
R-22 sold.
RV-8 AW Cert 02-09-17
N82 Sierra Tango
Avatar courtesy of AircraftStickers.com!
Dues gladly paid thru Nov. 2018(my reminder)
