Old 12-19-2017, 12:59 PM
Snap-roll Snap-roll is offline
Default Fwd.bagage bulkhead fluteing
Has anyone manged to get the two fwd.bagageroom bulkheads flat and warpless? Iíve fluted the c**p out of them whithout any success, it seems like the stiffner indentions are causing the warp and I canít figure out how to get the stress out, ideals?
Johan Sverkerson
RV 8
Hangar/work-shop done
Wings & empennage done
O 360 A4A picked up
Working on the fuselage
Rebuilding the engine
Old 01-10-2018, 09:45 AM
FlyGood FlyGood is offline
I bought my slow-build -8 kit third-hand and the two forward bulkheads were not very straight at all. However, when placed on a flat surface, they would lay flat with light hand pressure. I used them as they were, without any additional fluting. Mark the flange center lines as described in the instructions, and when it comes time to install the forward top skin, match drill the bulkheads starting from the longerons, working up, cleco-ing every other hole, or so. Adjust the bulkhead position by hand as you go, keeping the flange center lines visible through the holes. Much later in the build, when the top skin is riveted in place, the bulkheads will be straight forever.
Ken Cockrell
RV-8 Fuselage Slow-Build In-work; on gear
Tail Kit complete
Wings In-work
N247TM Reserved
Old 01-10-2018, 01:11 PM
Hi Ken, thanks for the input! i sort of got to the same conclusion to just leva it as is and deal with it when the time comes for riveting, it is after all a very good area to get your hands into compaired with many other places in the ” fuse”
Cheers Johan
Johan Sverkerson
RV 8
O 360 A4A picked up
