Old 12-17-2017, 12:19 AM
az_gila's Avatar
az_gila az_gila is offline
Originally Posted by rv7charlie View Post
Was that a response to my post? If so, I don't think I mentioned torque. C/S-ing a thin skin can compound the misalignment issue.
I see more misalignment if you use the Vans method of a screw in a reference nutplate and drill though the ear holes - rather than using a true nutplate jig.
The holes in the K1000 nutplates are spec'd at 0.098 +0.005 -0.000 inches, and most I have used tend to be a the high end of the specification, which is almost a #37 drill size.
Using a #40 drill though the platenut holes will give more misalignment that hand countersinking a hole made with a platenut jig.
The cost and stocking is negligible, you only really need the -3 and -3.5 lengths - anything that needs a longer rivet is thick enough to countersink.
I find them much easier to use, replacing 4 dimpling operations with two countersinking ones and never dimpled a single nutplate in my RV-6A
PS I forgot all the holes are now pre-punched, but it's still easier
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 12-17-2017, 09:57 AM
Gil,
My comments were specific to prepunched kits (-7, in my case). The slop in the #40 holes in the skin plus the ears of the nutplates can let the nutplate drift out of alignment enough that after riveting, screw insertion becomes...problematic. Dimpling the (pre-punched) skin and the nutplate ears seems to force the nutplate into alignment.
My experience, anyway.
Old 12-17-2017, 10:24 AM
Since this location is skin, fitting rib, fitting nutplate, I think if you're going to do it this way, why not just countersink the rib flange to accept the dimple from the baggage floor skin? You'll need a longer rivet than 3.5, of course.
Bob Collins
St. Paul, MN.
Almost ready to start the RV-12iS finishing kit. 480 hours in.
Builder log
Old 12-17-2017, 10:26 AM
Originally Posted by greghughespdx View Post
Dimple the things. Depending on your dimple dies you might have to/find it useful to grind down one side of the die so that might otherwise interfere with the nut part of the nutplate when squeezing. The ears will probably bend a little. They bend back.
Right, which an RV-12 builder would have done by this point anyway since instructions on the emp kit required the dimpling of the nutplate ears with this advice.
Bob Collins
St. Paul, MN.
Builder log
Old 12-17-2017, 10:48 AM
az_gila's Avatar
Smile
I think I misstated a little....
If it's thicker, then no need for the small head rivet, simply use a standard AN426 rivet.
Gil Alexander
Old 12-17-2017, 10:55 AM
az_gila's Avatar
Smile
Gil,
Yes, but I put most of this down to the larger holes in the ears.
I usually squeeze one rivet a bit, then set the second rivet and go back to the first. This lets the first rivet center itself in the larger ear hole and keep the main hole/nutplate alignment correct.
Since these small rivets don't need a lot of force, I hand squeeze all of them so the above steps don't really take any extra time. Clecoes can also push the nutplate out of alignment so if gravity and space allows I use a piece of stick tape to hold the rivets in place and hold the nutplate with my fingers for the initial small squeeze.
A nice bevel on the main holes helps a bit too with later screw insertion.
Building the -6A and using nutplates to hold down the baggage floor and seat panels instead of pull rivets gave me lots of practice.
Gil Alexander
