Old 12-11-2017, 10:02 AM
Low Pass's Avatar
Low Pass Low Pass is offline
Originally Posted by Saville View Post
Hi Brian,
What is the setback distance of your stick? The distance between the lines of the two vertical parts?
Thanks.
Vertical rise from pivot to centerline of joint, ~10.5" and the run from first joint aft is ~5.5". The angle is probably ~15 degrees off perpindicular.
Bryan
Houston
Old 12-11-2017, 10:37 AM
Saville's Avatar
Saville Saville is offline
Thanks Brian. Very helpful. Corroborates my own measurements.
My plan is to build a stick out of PVC without bends so that it passes underneath the lower edge of the panel and see if that gives me the height increase I need. If it does, I'll cut the new stick for that height and replace the old one.
If the height increase is not enough, then I'll play the cut and weld game.
Flying RV-8 N880BC
2019 Dues - happily paid.
Old 12-11-2017, 11:42 AM
springer springer is offline
Ah ok so the main benefit of the 2" adjustment seems to be to place the stick in a comfy position when at/near neutral. I understand that now.
I agree with you Saville about making the stick taller, mainly for better leverage as my -8 is nose heavy and aft for more comfort. I have never cared for the -8's stick ergonomics when compared to my -4, but I have learned to live with it.
Jim
RV-4 '88-'09 Built & Sold
RV-8 Purchased
Old 12-11-2017, 12:19 PM
akarmy's Avatar
akarmy akarmy is offline
FYI, Just keep in mind everything is a tradeoff. I tried the bent stick solution and while yes it makes straight and level very comfortable (for all the reasons mentioned) I found it ruined aerobatics and messed with my 3 point landings. Something about the position of my arm being further back reduced the leverage I got on the stick when pulling hard.
I ended up going back to the standard stick. But you can test it yourself once you are flying. (realizing that some do like it, as Jerry and others are flying with it moved back successfully).
Andy Karmy
Covington WA
RV-8 - Flying!
RV-9A - sold
Nov 2018 Paid
Old 12-11-2017, 05:34 PM
Scott Hersha Scott Hersha is offline
Sam -
Hah! I used a cool welding technique!
The paint I used to repaint was Ford tractor paint from Tractor Supply, which I thought was supposed to be the same color as Vans powder color - clearly it isn't, but so what.
The offset stick position is more comfortable to me (and most people I think), and allows the stick to remain as tall as possible. In some RV8's, depending on how it's rigged, the full forward position of the stick will contact the gear tower cross brace, even though it clears the bottom of the IP, so it would need to be shorter usually. My stick with grip will clear the bottom of the panel by 1/2" (top of cooley hat) and not reach the cross brace. If I didn't have the offset, it would interfere with the cross brace at that length.
On my first RV8 I did this same thing and it was perfect for me. On that airplane, I built arm rests that were in a normal arm rest position, unlike the orangutan designed position that is standard on the side walls, and it was perfectly comfortable for me. I could fly with my arm on the arm rest and move the stick all the way through a full stall three point landing with my wrist. It was never in the way. You should design your airplane with what works for you. This works for me - and the guy who bought my first RV8.
I am 6'1" with a 34" sleeve length, and a short stick way down between my knees isn't comfortable. If I gain 100 pounds, all in my belly, I may have a problem.
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Flying
Cincinnati, OH/KHAO
JAN2019
Old 12-12-2017, 08:11 AM
N729LS's Avatar
N729LS N729LS is offline
Two questions:
  1. Does anyone know, off the top of their head, what the wall thickness is of the front stick tube?
  2. Does this kind of modification, while increasing comfort, make it harder to get full aileron travel?
Andy
Andy Elliott, CFI, RV-8, N303RV
Flight Reviews, Dynamic Prop Balancing
KFFZ, Mesa, AZ
Old 12-12-2017, 09:23 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Originally Posted by N729LS View Post
Two questions:
Andy
1. Don't know
2. Nope
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 12-12-2017, 03:44 PM
scard's Avatar
scard scard is offline
.035 wall
(other useless words here)
Scott Card
CQ Headset by Card Machine Works
RV-9A N4822C flying 2000+hrs. / Cedar Park, TX
Old 01-10-2018, 01:40 PM
WA85 WA85 is offline
Default RV-8 S Bent Stick PIREP
The original front control stick I put in my RV-8 was a stock Vans stick, with no bends and a Tosten grip. The overall height of this configuration was 13.75" from the center of the pivot mount bolt to the top of the grip. This provided approximately 3/4" clearance between the top of the stick and instrument panel and 1/2" at the gear tower cross over brace. The Tosten grip is excellent and in no way do I want to say that it is a bad design, but I will admit I did a poor job of incorporating it into my initial stick configuration. The Tosten grip requires the stick to be cut off fairly low in order for it to plug into the 1" diameter hole in the top of the stick. The Tosten grip also has a very ergonomic forward cant, however this also has the affect of moving the grip point of the grip forward vs a more vertical grip. I contacted Mike Cingari (who used to offer RV-8 stick bending services, now it is Karlo Gatdula) and had him make an "S" bent stick for me. The stick I got back had some wrinkles in the bends and I was concerned about loosing strength due to the wrinkles. Before installation, I load tested the S bent stick with 100 lbs in four directions to see if the S bent stick would fail due to the bends or wrinkles, it didn't budge at all. I figure if I have to pull more than 100 lbs while in flight, I will have other problems. The Tosten grip can no longer used since the S bent stick would have to be cut off right at the top of the bend, so I had to use a slip over type grip. I chose a 1" diameter polished wood grip form Acft Sp that had a PTT hole already drilled. I cut the S bent stick to 13.80" and this allows the slip over grip to just barely bottom out before the bottom of the grip reaches the top of the bend. In this configuration, the overall height of the stick is 14.18" tall, which clears the instrument panel by approximately 3/8", with the PTT rubber button being the highest point. Since the S bent stick moves the vertical axis of the stick about 1.75" aft, the grip doesn't come close to the gear tower cross over brace. Ergonomically, the S bent stick is much more comfortable, it allowed my to remove a seat back cushion and allows for what I think is "normal" hand / arm positioning during flight instead of a forward hunched position. A side affect was that the stick is not slightly longer and the stick forces feel a bit lighter, plus the muscle memory is different, making for a slightly odd feeling during the first test flight and acro. The combination of a 1.75" aft S bend, a more vertical grip axis and being slightly taller, all add up to a much better configuration for my RV-8. Overall, I would recommend the S bent stick to any RV-8 pilot / builder as a safe and ergonomic improvement to great design.
