Old 07-18-2017, 11:01 AM
SteinAir SteinAir is offline
Default New (July 2017) Garmin ADS-B Products
I haven't seen this out there yet, but it may be of interest to folks wondering about yet more ADSB solutions!
The GDL-82 is a neato inline box that you simply plug into your existing transponder installation and uses your existing antenna (but you will need to install the GPS antenna):
http://newsroom.garmin.com/press-rel...out-general-av
and these are receivers for both ADSB and/or XM.
http://newsroom.garmin.com/press-rel...iusxm-aviation
I'm sure the G3Xpert folks can provide additional information!
Stein
Old 07-18-2017, 11:10 AM
Cost?.....
Old 07-18-2017, 11:11 AM
Originally Posted by Mike S View Post
Cost?.....
I believe the GDL-82 is around $1795, the GDL51(r)/52(r) around $649 & $1149 respectively.
Stein
Old 07-18-2017, 11:12 AM
YellowJacket RV9 YellowJacket RV9 is offline
Cost?.....
$1795 per kitplanes https://newsline.kitplanes.com/2017/...eral-aviation/
Still not quite beating the GRT system ($100 off right now, BTW) which includes ADS-B IN, but the inline installation looks slick.
Chris
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
Old 07-18-2017, 11:51 AM
jliltd jliltd is offline
With the GDL-82 being a UAT out product, does it have anonymous mode capability when squawking VFR like other UAT products?
RV-8
RV-3B
Old 07-18-2017, 12:52 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
Neat idea -
Works in the US only... no trips to Canada or Mexico I think...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 07-18-2017, 01:07 PM
uk_figs's Avatar
uk_figs uk_figs is offline
If I read this correctly with my GDL 39 D, GTX 327 and 796 this solution would make me ADS-B compliant, is that correct? Quite a bit cheaper than replacing the 327 with the 335 transponder and less behind the panel work. I assume that the GDL-82 GPS would become the master?
Figs
Dave (Figs) (RV-7 N256F, Flying)
Dave's RV-7 Blog
Email me
Old 07-18-2017, 01:10 PM
Not as of yet. I have many Mexican citizen aircraft owner customers and they scoff every time I bring up the ADS-B out issue. They have zero plans to implement ADS-B in their aircraft whether X-numbered or N-numbered. Many of whom are well connected with the government of Mexico and "in the know".
And I sat next to avionics tech from Canada at an AEA training seminar last Fall and understand from him NavCananda is only going to require ADS-B out in one or two territorial regions, at least for any time in the immediate future.
So almost all the pressure to equip is coming from the FAA and big avionics manufacturers. Not our neighbors to the North and South.
Jim
RV-8
RV-3B
Old 07-19-2017, 07:11 AM
ColoCardinal's Avatar
ColoCardinal ColoCardinal is offline
Does anyone know how the Garmin mail in rebate works. Do I need to go to Airventure or can I send a "proxy"? Does the purchase need to be made at the show?
Carl - - Morrison, CO
N16CB will fly this year!
Paint booth built and in operation. final fitting of everything soon. Inspection in June?
paid 'til 10-18
Old 07-19-2017, 07:18 AM
N427EF N427EF is offline
Default Glad I waited
Glad I waited to ditch my Garmin 327.
This looks like a very neat and simple solution for a good price.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 400 plus hours
Over 2500 Gallons of E10 mogas burned
Don't believe everything you know.
