Old 08-13-2015, 01:12 PM
Gandalf Gandalf is offline
Default 31b-21 Step 3 Backshell
I called Vans today when I was unable to locate the ES 9 Pin Backshell 2 in my finish kit. The ES 9 Pin Backshell 2 required for step 3 is not included in the finish kit. So no need to search for the missing part, the backshell is part of the Avionics kit.
Jeff
Old 08-13-2015, 10:52 PM
Bill_H's Avatar
Bill_H Bill_H is offline
FYI:
The backshell to that DB-9 is special because of the screws - the "Backshell 2" as listed by Vans. Remember, the backshell is not the plug! The backshell 2 has shorter screws that require a screwdriver (shorter than all of those thumbscrew-type backshells behind the panel) that do not interfere with the magnetometer that is part of the ADAHRS unit. (But they are NOT "non-magnetic" screws.)
Old 12-20-2017, 07:45 PM
Bmoore4rv Bmoore4rv is offline
Default es 9 pin backshell Thanks -
post of backshell furnished in the finish kit - saved lots of time
