Originally Posted by Canadian_JOY
I would love to hear more about the upcoming N16 nav radio.
Rainier - when you have a moment to spare, would you mind sharing here an outline of the N16's capabilities and interfaces, please?
Sure,
bit of history first. I wanted a NAV radio for a long time. But with our previous arrangement (where a third party was doing the hardware implementation and production) nothing ever happened. Just talk and dummy prototypes for Oshkosh. That was embarrassing me no end.
Anyway, that changed.
The V16 was also supposed to be the PCB for the NAV radio (just leave out the transmitter and fit another filter for the glide slope and different firmware). That did come to pass (so the N16 does exist) but I decided to make a dedicated PCB for it to simplify manufacturing (and it also allowed a more optimized input stage for the receiver without having to compromise).
The production prototype is currently being put together - I'll still fiddle with the software a bit but the actual NAV stuff is done (and working to an exceptional degree of accuracy due to fully digital, drift free implementation. There are times I just love applied maths. This is one of those times).
So what does it do ? Quite boring really - ILS, glide slope and VOR. Dual VOR or single ILS with glide slope. Station morse decoder, the usual audio out (that nobody really uses). Pretty similar to what your run of the mill NAV radio is supposed to do...
If you are not planning to connect it to an MGL EFIS - via either the Razor or Vega head you have RS232 emulating a you know who NAV radio and if you spring for a V16 as well - then it looks just like your standard old NAV/COM. In the control head select if it should look like a older SL30 or one of the newer types.
Price - since it is basically a V16 minus the transmitter parts - it follows it should be somewhat less than a V16...
Rainier
CEO MGL Avionics
