Old 03-04-2017, 05:37 AM
dtw_rv6 dtw_rv6 is offline
Default Tip: 3d Printed Accessories
Here are a few of my 3d printed accessories - all in polycarbonate and printed on my home brewed Prusa i3 style printer. 3d modelling is in solid works, and I use both Cura and Slic3r to output the machine codes:
1. This is my overengineered drink caddy. It also includes pockets for sunglasses, two usb thumb drives, and a miscellaneous slot that I use for keys and/or usb cables. The vise grips were for a temporary fit up. I've replaced it with 2x #8 screws/platenuts since this photo was taken.
https://drive.google.com/open?id=0B_...kpuRldwckN6S3c
2. Replacement battery box for my EarthX. On top of the weight savings of dumping my PC680, I realized that the aluminum box that came with my -6 kit weighs a lot too. This one checks in at around 1 pound.
https://drive.google.com/open?id=0B_...y1ZTXFCMV9JVjQ
3. Bose headset volume controller cradle. I fastened this to the side of the cockpit. The arm hanging off to the side is just big enough to hang the headset on when I'm getting in and out of the cockpit. I mount it just under the panel elevation so I don't snag it on my leg. I also have one for my Zulu headset. The controller easily comes out for battery changes:
https://drive.google.com/open?id=0B_...zNpcXpvQ2w0RWc
Old 03-04-2017, 05:50 AM
Weasel's Avatar
Weasel Weasel is offline
I have a lot of fun playing with the 3d printer, it also really can push a guy close to insanity.
Weasel
RV-4 715hr Sold
RV-10 "School Bus" - +1500hr counting
Fisher Classic Cassler Power VW sold
RV-10 N7631T 820hr Sold
RV-8 700+hrs
Carbon Cub 200 hr Sold
One-Off Super Cub 100 hr
SERFI AWARDS
http://weaselrv10.blogspot.com/
Old 03-04-2017, 07:00 AM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Default wow
wow...nice work...
I can barely use a paper printer.....I am old!
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1150+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 03-04-2017, 07:38 AM
I never really thought I had ADD until I installed a camera on my printer for controlling it remotely. I'm usually watching it on my laptop out of the corner of my eye when eating dinner or watching the evening news. I used to do it because I hadn't learned how to reliably get good bed adhesion, but now it's just mesmerizing to watch my parts growing out of the nozzle.
I built this printer after I convinced myself that I really didn't need a used bridgeport and lathe in my basement for making this type of stuff from metal. In the end I think I made a good choice. The printer is much simpler, quieter, and cleaner to have in the house. Not sure my wife fully appreciates that though
Don
Old 03-04-2017, 09:40 AM
Default 3D challenge
nice work Don.
I have an antenna that looks like this.
How can I make it look more like this and gain a few knots?
or this?
Old 03-04-2017, 04:03 PM
Weasel's Avatar
Originally Posted by Steve Melton View Post
nice work Don.
or this?
Good idea Steve maybe if you would model the antenna that you have then give it some Clarence and make a fairing in the shape that you want around it. Basically a hollow fairing slipped over the existing antenna and use the same mount holes to secure it.
Weasel
RV-4 715hr Sold
RV-8 700+hrs
SERFI AWARDS
Old 03-04-2017, 04:42 PM
Google the effective shape of a swept cylinder, 1st. You might find a better use of your time/plastic.
Old 03-04-2017, 05:10 PM
didn't find much. not much sweep on this antenna.
Old 03-04-2017, 09:20 PM
didn't find much. not much of sweep on this antenna.
I'm on the road & can't find the reference, but take an imaginary slice through the antenna shaft, normal to the air flow. It will yield a section fairly close to a streamline, or teardrop, without the pointed tail. Not perfect, but much lower drag than a cylinder. IIRC, that's why they are swept.
Old 03-05-2017, 03:45 AM
ok, I understand the concept. thanks.
data from the website.
first antenna
The antenna is designed to operate at speeds up to 350 mph and altitudes of 50,000 ft. It has a drag force of 3.43 lb @ 250 mph
second antenna
The antenna is designed to operate at speeds up to 350 mph and altitudes of 50,000 ft. It has a drag force of 0.85 lb. @ 250 mph.
