Old 11-08-2016, 07:39 PM
Tram Tram is offline
Default G5 NAV data..
Anyway to get NAV data to a G5 from an iPad or are they gonna try and force me to go G3X?
Old 11-09-2016, 02:55 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Post
Hello Tram,
Section 1.7 of the G5 installation manual provides guidance for connecting a wide variety of navigators from portable GPS units to panel mount IFR navigators using RS-232 and in some cases CAN bus. A G3X system is not required.
For a portable navigator like the Aera 660, the G5 receives both lateral and vertical VNAV guidance over RS-232 using a NMEA format.
We are not aware of any method to use an iPad as a navigator.
Steve
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 11-11-2016, 09:20 AM
While that is a bummer, I appreciate the reply.
Old 11-11-2016, 10:07 AM
RV6_flyer's Avatar
As of November 2016, there is NO WAY to get NAV data from an iPad to any other device. Yes you can look at the iPad and program another device to try and do what you see on the iPad but it will not run an autopilot as there is NO serial (RS232) port to output the data needed.
If someone knows a way, a new thread needs started to teach the world how to do it.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 11-11-2016, 01:23 PM
MS19087's Avatar
MS19087 MS19087 is offline
Default Slightly different question
If one sends nav data from a 796 to the G5, will the G5 display nav vectors or HSI guidance for the flight plan in the 796?
RV-9A; IO-320 w/ Whirlwind WW-151
(Flying since June 2011)
RV-14A; building
2019 =VAF= donor
Old 11-12-2016, 02:35 PM
chuckwn's Avatar
chuckwn chuckwn is offline
Default G5 and Autopilot to Android
It is possible to connect the Avare app to an autopilot (and a G5) using the Avare IO plugin and a bluetooth serial adapter.
Any iOS app could add this functionality if they so choose.
https://apps4av.com/2013/11/10/avare...xternal-io/#ap
http://www.mouser.com/ProductDetail/...zJrkvm4.mailto
Chuck Newman
Petaluma, CA
RV-8 N828RV
Old 11-13-2016, 04:17 PM
g3xpert's Avatar
Post
Hello Mark,
Yes, the G5 installation manual shows how to use one of the two serial ports on the 796 (configured for NMEA Out) to provide lateral and vertical (VNAV) guidance to one, or multiple, G5 units.
Let us know if you have additional questions.
This thread also has additional information.
http://www.vansairforce.com/communit...d.php?t=136282
Steve
Garmin G3X Support
g3xpert@garmin.com
