Old 10-05-2017, 08:24 AM
Tram Tram is offline
Default Fiberglass needs a little help..
Passenger side of the canopy needs a little help. Couple years ago the canopy slammed and popped some filler out of a rivet.
Noticed last night the fiberglass surround at the rear of the canopy has taken it on the chin lately.
How would you fibgerglass experts go about repairing this?
https://imgur.com/gallery/X92ut
Old 10-05-2017, 08:41 AM
rv8ch rv8ch is offline
Default Like dis!
I'd use Dan's tips to fix this: http://www.vansairforce.com/communit...ad.php?t=81595
I've used this method on my canopy skirt and it worked swimmingly. Then you have to paint, or find a painter - that's a horse of a different color.
Mickey Coggins
http://rv8.ch
Old 10-05-2017, 04:32 PM
snopercod's Avatar
I would use Dan's method, but with two bid on either face. I'm sure you know this, but sand off the paint until you reach fiberglass. Peel-ply is your friend.
(2019 dues paid)
Old 10-07-2017, 07:00 PM
I'll pick up some flox and see what happens..
Old 10-07-2017, 07:59 PM
Ron B. Ron B. is offline
In my opinion repairing with a flox mixture on this edge would not be my choice of repair. This edge was damaged by being hit numerous times and flox will not stand up to this abuse anywhere near as if it was repaired with glass. I would sand down the area to be built back up, probably from the inside and like in Dan's example apply a smooth material as a backing mold to the exterior and build up the glass. I would tend to have a longer scarf , removing some good original glass to make a longer bonding point for the new lay up to bond to, due to the high wear area we are talking about.
Thanks Ron
RV-10 SOLD
RV-14 Flying
Old 10-07-2017, 08:29 PM
Timberwolf Timberwolf is offline
Personally, I would make the targa strip out of aluminum. None of the issues associated with the glass. Mine has bent at one corner from the top smacking down in the wind. I was able to bend it back out. It would have shattered fiberglass. In this case I think it's a better choice for the application.
Shane
RV-6 IO-360 Angle valve, G3X touch
Murphy Moose M14P in progress
Aero Engineer, A&P
Old 10-07-2017, 08:57 PM
I'll have to consider this.
That sounds like a good ide, but I didn't build this plane, so gathering up the builder tools that this would require may not prove cost effective.
Old 10-08-2017, 06:24 PM
All it requires is a strip of aluminum and fasteners. Anything from Avex rivets to low profile Allen head bolts. Drill holes and bolt/rivet it on. No special tools required.
Shane
Aero Engineer, A&P
