claycookiemonster
If the Firewall is supported by a rotisserie, is there any reason not to use the tail wheel mount to hold up the tail? I'd guess it's stressed for all the vertical loads it might encounter during construction, but what if the fuse is on it's side or inverted? Does anyone have any sense of the engineering that went into that tube back there and what sort of side or inverted loads it can safely bear?
