Old 02-18-2020, 01:40 PM
papamike's Avatar
papamike papamike is offline
Default P-Mag manifold pressure connection
Hi,
I have the Dynon manifold pressure sensor and 2 P-mags. Do I just tee the two p-mags together with the manifold pressure line off the engine, then put the one line into the Dynon sensor? There's only the one input to the sensor.
TIA...
Pete Miller
RV-7 Firewall Forward
N174PM (reserved)
McKinney, TX (T31)
http://smilinpete.com
Old 02-18-2020, 01:56 PM
azflyer21 azflyer21 is offline
Yes, one line off cynlinder #3, then teeing off to both mags and the sensor. Here is a picture of the tee at the mags https://webuildplanes.com/kevins-rv-...final-plumbing. I got my firewall forward hoses from Aircraft Specialty and they supply all connections.
Kevin Lippert
Zenith 750 completed 2016 -
Sold
RV-14A N1402 Flying 03-2020
New Build Log
Old 02-18-2020, 02:18 PM
N941WR's Avatar
N941WR N941WR is offline
Yes, they can all be tied together; however, you want to make sure you have some type of restrictor installed in the line before your P-mag connections.
We have discovered that some EFIS's will "smooth" the MAP readings in their software and some wont.
What happens to the P-mags is that they can get different pressure readings and set the P-mags to different timing. None of this will harm you plane but aren't maximizing the efficiency of your P-mags.
Also, remember to time them correctly for your engine. The standard timing is a bit too aggressive.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 02-18-2020, 04:31 PM
We typically use a -3 hose off the #3 cylinder. To connect to a Dynon MAP sensor, we use a short piece of DTL6000 hose crimped to a -3 Male AN fitting that we make. The rubber hose on the MAP sensor fits tight and leak free. Because the sensor has a plastic tube stub thats 1/4 OD, you would have to adapt a -5 teflon hose, then the teflon is stiff and doesnt seal that well over a beaded tube. The rubber hose isnt sexy, but it sure does work.
Tom
Ridgeland, SC
Old 02-19-2020, 09:00 AM
John Tierney John Tierney is offline
I ran a braided hose from the engine (#3 Cyl.) to one of the ports on the Van's transducer mount on the fire wall. Then went to the hardware store and got various tees and adapters to connect from the transducer mount to the Dynon MAP sensor and to the PMAGs.
https://shop.vansaircraft.com/cgi-bi...ct=va168-va188
John Tierney
Vonore, TN
RV-7A - N777JT Flying
Old 02-19-2020, 10:41 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Default manifold pressure hose
I got some model airplane T fittings, some rubber hose, a connection to a bit of braided -3 hose to cylinder #3.
Couple more pictures here:
http://www.rv8.ch/manifold-pressure/
Would be great if these MP sensors were a bit smaller and happy to be under the cowl. At least the PMAG fittings were quite easy to hook up. Mine came with hose that I didn't use, I found something a bit more heat resistant. Probably not needed, but why not?
With about 1 hour of ground running it's working great!
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 02-22-2020, 10:01 AM
avrojockey avrojockey is offline
This ^^^^^^^
I had fluctuations in my MAP readings on my G3X and just lived with it until I installed my P-Mag then I installed a snubber to smooth out the MAP variance. This is what I purchased...
Brass, 1/8 NPT Male x Female, 0.004" Orifice Diameter, PN 3820K11
I thought a .004 orifice might be too restrictive and cause a lag in my MAP indication, but it worked great! My MAP indication is rock steading and responsive to any power change. I did install it at the stock Van's transducer manifold rather than at the #3 intake to limit the possibility of the orifice becoming plugged. Then I used the plugged MAP tap to install a 1/8" NPT to 1/8" Male barb to connect my my PMag MAP tubing.
Tim Holmes
Appleton, WI
ATP, CFI/II/MEI
RV-9A N904DC
2019/2020 Dues Paid
Old 02-22-2020, 11:49 AM
rv8ch's Avatar
Default Snubber
Originally Posted by avrojockey View Post
This ^^^^^^^
Never knew what they were called - thanks!
Mickey Coggins
http://rv8.ch
"Hello, world!"
