Old 11-13-2018, 10:03 AM
jcaplins's Avatar
jcaplins jcaplins is offline
Default subaru engine prop combo survey
For those of you running a subaru engine and not on the Yahoo subenews group, I have created a quick survey:
https://www.surveymonkey.com/r/QBCBMXY
Since I don't know all the combinations, I'll see how many of the "other" boxes are filled in and may create a new survey later.
Jeff Caplins
California
RV7 N76CX
(started: Feb 2002 --> Completed: May 2016)
Old 11-19-2018, 08:46 PM
charosenz's Avatar
charosenz charosenz is offline
Jeff,
Hope you get a good number of folks to share their info with you. Even though I am not a soob guy, I would like to see the results, there is a lot of valuable info there for those of us who are in over on the dark side of "experimental" aviation using "alternative" engines.
Good luck to you.
Charlie
Old 11-20-2018, 12:59 PM
Lufthans's Avatar
Lufthans Lufthans is offline
I just LOVE my EJ-25 installation on my Jodel. Has proven extremely reliable, very powerful and smooooooooth.
Next project (once I've finished a number of other things) will be a Rocket with a supercharged EJ-25 of around 350 to 400 hp and hydraulic MT prop. Enduring the IO-320 in our -4 in the mean time... (which admittedly isn't such a bad thing either. Not as nice as a well-executed Subie conversion though)
Hans Teijgeler
Hilversum, The Netherlands
Preparing to build a Rocket
PH-BRR Bowers Fly Baby; Imported and upgraded
PH-MGA Jodel DR1050; Built, with Subaru EJ25
PH-SUM RV-4; Imported and upgraded. Sold my share :-(
PH-EIL RV-4; Imported and upgraded for friend. Sadly crashed
PH-ERD Robin DR300; Built with Subaru EZ30 for friend.
Old 11-20-2018, 01:06 PM
simpkinsona simpkinsona is offline
Default Thanks Jeff
Thanks for posting this here. Maybe a few Subaru pilots will see it and find out about the Yahoo group.
-Andy
Andy Simpkinson
RV-9a Subaru engine.
Old 11-20-2018, 01:18 PM
Lufthans's Avatar
Which one do you mean Andy?
Hans Teijgeler
Old 11-21-2018, 07:07 PM
jcaplins's Avatar
I've gotten 20 responses so far. I posted some of the earlier results on the other group, I'll post it all here soon.
Jeff Caplins
California
RV7 N76CX
Old 11-21-2018, 07:51 PM
Default Subenews
Groups.yahoo.com
Then search “subenews”. You have to request to join. I’m sure the moderator will accept you. There’s lots of archives to research the collective knowledge of subaru flyers.
-Andy
Andy Simpkinson
Old 11-22-2018, 12:53 PM
jcaplins's Avatar
21 responses.
I was limited to the number of questions to ask and you could only enter whole numbers. I made the mistake of not specifying engine vs prop rpm; most people put engine rpm, but for the few that entered prop, I converted the number to engine rpm based on what I thought your PSRU gear ratio.
So, I took the info and put it in a google doc as a simple spreadsheet. You can sort things to compare whatever you like. I have it set so anyone can edit the file, so if you would like to fine tune your fuel flow or airspeed, or add/correct things, feel free and I would appreciate it.
https://docs.google.com/spreadsheets...it?usp=sharing
Interesting findings for me: My top speed is up near the top for my airframe, but fuel flow to get there is waaaay higher. I also burn 2.5 gph more to cruise at the same speed compared with other 6 cyl RV7s.
Jeff Caplins
California
RV7 N76CX
Old 11-22-2018, 04:44 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Interesting. I recognize some of the planes from the data. No surprise a turbo 7 can do 220 KTAS at altitude at 50 inches. It's producing around 240-250hp at that power setting.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, RV6A C-GVZX flying from CYBW since 2003- 429.6 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi.htm
Old 11-26-2018, 08:28 AM
Lufthans's Avatar
Originally Posted by simpkinsona View Post
Groups.yahoo.com
-Andy
Ah, the Eggenfellner forum. I've been a member pretty much from the start.
There also used to be (and maybe still is?) Airsoob, Flysoob and late Garfield Willis' AirSIG. Lots of knowledge there...
Hans
Hans Teijgeler
