NorthernRV4
I'm currently working on the RH elevator skeleton and I'm at the point of installing the spar reinforcement plates to satisfy SB14-02-05 as a preventative measure. Since Vans doesn't provide dimensions for the .063 plates I thought I'd simply make them like I did the E-411/410 plates but should I make them the same length and match drill all the holes? The PP kit from Vans has a different hole pattern and are clearly shorter to allow installation in a finished elevator where you'd be working through the opening in the LE. Thoughts?
