Bob_pipedream
Hi All,
Question regarding aileron rigging on an RV6
Before I start ? have checked that the bellcranks are in the right way round and understand differential ailerons etc. I have also verified that ailerons are neutral and all seems nice.
I have got 30 degrees up and 16.8 degrees down on one and 15.8 degrees down on the other with enough threads engaged (1/2 of the rod ends on the small pushrods engaging in the pushrod and all of the threads on the long pushrods engaged) ? so she should be safe.
However to get to this state, I had to adjust out (lengthen) the small pushrods leading to the ailerons by about ?? to ?? from the standard bellcrank neutral position otherwise I would have only had 14 to a maximum 15 degrees of aileron down travel. Obviously I then had to adjust-in the long pushrods by a similar amount in order to get the ailerons neutral at rest again (checked neutral by using long straight edge across the tooling holes in the ribs).
Also in the standard position it felt as if the down-aileron pushrod was over-centering on the bellcrank when fully extended.
Is it normal to have to lengthen the small pushrods to change the bell crank position? Also am I the only one to feel as if in standard set-up, the bellcrank was over-centering when installed as per plans?
I and my inspector are happy with how they now sit, but as first flight is this week, for peace of mind, I just wanted to sound out if others have found the need to adjust-out the small pushrod?
