Old 12-06-2018, 11:44 PM
az_gila's Avatar
az_gila az_gila is offline
Question Load shedding with boxes using back-up batteries
I'm doing some forward planning with my VPX system but the answers may also apply to AeroElectric Main/Endurance bus users.
I just found out that you can't 'make' a Dynon Skyview system go into "back-up battery mode" without switching off it's 12v source. So if you want to conserve main battery capacity in an emergency you need a separate power switch. The unit will only go into internal battery mode when it loses it's power source.
This makes a difference if you are using the VPX Back-Up METHOD B from their manual. You need a "load shedding" switch on the panel for the Skyviews, preferable one with a safety switch cover.
These switches would help load management if the electrical system or VPX unit goes belly-up.
Besides helping others planning on VPX units, I am wondering if this "no manual method of going to back-up" is prevalent for other units such as the Garmin G5 I'm planning on and should be accounted for.
Please no "don't use a VPX" responses...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 12-07-2018, 07:18 AM
219PB 219PB is offline
Gil,
I have the VPX set up on my system with two EFIS. Did not install a backup power for them because I installed the Dynon backup batteries. I figured that if the VPX did go "belly up" that it would stop supplying power to the EFIS. The Dynon backup up automatically kick in then. If I needed to load shed because of a battery or alternator problem, I would shut the power off using the VPX screen on the Dynon. My reliability model did not include multiple failures, such as concurrent alternator and VPX failures.
Paul Bonorden
RV-6A under construction
My Builders Website
Victoria, TX
2019 Dues Gladly Paid
Old 12-07-2018, 07:32 AM
jwilbur jwilbur is offline
Originally Posted by 219PB View Post
Gil,
Same here. To account for partial VPX failure such as only one bank going south, I have judiciously assigned components. For example, each Dynon screen is on a different power bank.
-Joe Wilbur (N520LW)
Phase II - 11/2017
First flight - 8/2017
RV-10 Build Log
Old 12-07-2018, 08:10 AM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is online now
Wow - talk about testing one’s restraint....
Old 12-07-2018, 08:17 AM
rocketman1988 rocketman1988 is offline
Default Good on you!
Gil,
Good on you for adding your qualifying remark about "not using the VPX".
There are SOOOOO many people on these boards that believe their way is the ONLY way...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
ShowPlanes Cowl with Skybolts Fitted - Beautiful
Wiring...
Dues Paid 2018,...Thanks DR+
Old 12-07-2018, 10:46 AM
majuro15's Avatar
majuro15 majuro15 is offline
Could you achieve your desired results with an avionics master switch? That's what I had planned for when doing VPX (I'm now using the ACM from AFS, but nearly the same thing). You could put the PFD, EMS, Comm 1, Nav 1, GPS on the Master and then assign all other electronics to Avionics Master. One switch and you killed anything extra. For that matter, you could simply choose to put the G5 and a gps/comm on the Master then have everything else on the avionics master although start up might be a challenge.
www.N1017H.com
Tim Huneycutt, Capt, NCANG
RV-10 Finish kit under construction
N1017H Reserved
EAA #: 1106970
2019 VAF Dues Paid!
Old 12-07-2018, 11:13 AM
az_gila's Avatar
Thanks.... I'll have to think about that a little more.
It's an interesting re-defining of the VPX switch functions.
Gil Alexander
