Old 10-26-2018, 08:03 AM
DanH's Avatar
DanH DanH is offline
Originally Posted by dwranda View Post
Did you actually trim/sand the front to match the plywood disk before mounting the cowl on the plane?
http://www.vansairforce.com/communit...60&postcount=2
http://www.vansairforce.com/communit...9&postcount=12
Dan Horton
RV-8 SS
Barrett IO-390
Old 10-26-2018, 08:28 AM
dwranda dwranda is online now
This is all fantastic stuff guys!! Thanks for the help. I'm feeling a little more confident now. Keep it coming if anyone has anything else. On another note I think James also sent me the wrong air inlet ring. It seems way too big for that small lower hole. I will be calling them today. Yesterday I was kind of regretting getting this cowl vs the standard one. Hopefully today goes better!!
9A in progress
Working on Finish kit!!
Mattituck TMXIO-360 red gold
Dues paid Dec 18
Old 10-26-2018, 04:40 PM
Progress so far copying the Dan H photos. I've got the center circle a perfect 13" but the outer ones are still 1/4" to 3/8" too big. I sanded the top cowl straight across and if I keep sanding to get the outer circles right, the center one will be less than 13. Opinions?
9A in progress
Dues paid Dec 18
Old 10-26-2018, 04:44 PM
BillL BillL is offline
Please show or sketch what your reference points are for saying the inlets are off.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Instrument Currency 12-17-18
Old 10-26-2018, 05:52 PM
Well I went out to take a pic of what I was talking about and decided to sand a little more. I guess I got the outer holes close enough to 5 1/4. It's hard to fully tell when the sides are overlapping and things aren't lined up perfectly though. I think I'm ready to move on to the next step!
9A in progress
Dues paid Dec 18
Old 11-28-2018, 04:47 PM
Av8torTom's Avatar
Default Fiberglass
Hey Dave, if you need any advice fiberglassing give me a call. Also, those "spider" marks you mentioned do indeed look like vacuum bag wrinkles and are most likely cosmetic. You can probably just fill with thickened epoxy and smooth.
I'm also planning on a SJ cowl so you better get this figured out! -
RV-9A (empennage completed, both wings completed, fuselage and finish kit completed, engine hung, working on panel and wiring)
N677AT reserved
Superior XP O-320, 160HP
Old 11-28-2018, 05:07 PM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Define the intake diameter
I just went through this delimma. The intake opening is nebulus with regard to diameter due imperfections in resin/glass. It looks like your “ horizontal centerline” can be moved more toward the outer surface of the cowl . As stated above, the bottom line is a “ fit” to the aluminum ring bearing surface. As Dan says, the rest is just glass and subjective symetry.
Larry DeCamp
RV-3B flying w/ carb / Pmags / Catto 2b / Steam
RV-4 fastback w/ Superior XP360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 11-28-2018, 06:10 PM
Thanks Tom. Finally got the skybolts where they need to be around the firewall. Next is the skybolts on the seam. Hopefully they turn out alright.
As far as the cowl goes I am disappointed in the quality. The halves didn't line up very well together and there was hardly any overlap near the front. I ended up cutting one side too much(my mistake) so now I have to add some back on. This is my first plane but I had one builder tell me these cowls were a work of art. Mine wasn't. The upper cowl maybe but the lower not even close.
I also think they sent me the wrong metal inlet ring for that lower hole so I need to contact them about that.
9A in progress
Dues paid Dec 18
Old 11-28-2018, 10:03 PM
N941WR's Avatar
N941WR N941WR is online now
Default One other tip
After you fit the cowling together, you will run either a hinge or brackets for quarter turn fasteners up the side but they will not make it all the way up to the round opening.
Fiberglass in a lip on the bottom section, that sticks up and behind the top section, from the end of the hinge or quarter turn fastener supports to the round opening.
This will help prevent air from entering the low pressure side (bottom) of the cowl and when you paint your cowl, it will get painted a well and help hide the black line from the cowl split.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
