Old 10-26-2018, 09:29 AM
zoelt zoelt is offline
Default gross weight increase ELSA
Can anyone tell me / reference me the steps to recertify an ELSA compliant RV9-A to Vans recommended gross weight of 1750#? With Basic Med I no longer need ELSA compliance and potential purchaser wants it certified higher
Tim
RV 9-A N932WF, ELSA compliant gross weight 13230#
Old 10-26-2018, 09:34 AM
Mel's Avatar
Mel Mel is offline
No problem. Since the aircraft is certificated as experimental amateur-built, you may place the aircraft back into phase I and test the aircraft to the new gross weight. The process is listed in you operating limitations. Depending on when you op lims were issued, the latest version, this would be paragraph 14.
A&P/EAA (LifeTime) Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
RV-6 Flying since 1993, 172hp O-320, 3-Blade Catto (since 2003)Sold
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 10-26-2018, 09:57 AM
N941WR's Avatar
N941WR N941WR is offline
What Mel said.
Just keep in mind that once you go up, there is no going back down.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
MercFE MercFE is offline
Mel, I've often wondered if this process applies if you are not the builder of the aircraft. I assume so, but have not found anything that justifies it.
Old 10-26-2018, 10:39 AM
Mel's Avatar
Mel Mel is offline
Yes, this applies to anyone. The only time the "builder" is required is for the annual condition inspection. And then he/she must hold the repairman certificate for that aircraft. Any maintenance and/or modifications may be done by anyone. Of course there is always the legal vs. prudent question!
North Texas (8TA5)
FRIEND of the RV-1
Eagle's Nest Mentor
Old 12-07-2018, 07:27 AM
airguy's Avatar
airguy airguy is offline
Any further news on this original subject?
Greg Niehues - PPSEL, IFR, Repairman Cert.
Garden City, TX VAF 2019 dues paid
N16GN flying 400 hrs and counting! Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
Old 12-07-2018, 07:33 AM
Mel's Avatar
Mel Mel is offline
If you are referring to an increase in gross weight for LSA, then just sit back with a BIG bag of popcorn. The NPRM is planned for January, 2019. With comment period to follow (and there will be many), my prediction is that it will be at least a year before anything happens.
North Texas (8TA5)
FRIEND of the RV-1
Eagle's Nest Mentor
Old 12-07-2018, 09:21 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Actually Mel, they plan to stat WRITING the NPRM in January, so make that at least two Big bags of popcorn.....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 12-07-2018, 11:28 AM
DaleB's Avatar
DaleB DaleB is offline
We should get a pool going. Of course we could all be dead by the time the results are known.
Dale
Omaha, NE
Previous RV-7 project (sold)
