SuperCubDriver
I am about to install the Grove airfoiled legs. I didn?t get instructions with the gear legs, may be we just have to use the Vans instructions.
I understand that I should use the Vans supplied wear plates and the Grove attach brackets. For the outer brackets In the Vans construction manual it is said to match drill the outer holes through the U-brackets into the fuse. However there are prepunched smaller holes in the fuse and the weldment in the approximate location and when following the manual they are not used or just "drilled over". Am I overlooking something?
Here are two pics for clarification
Underside of fuse
Inside the gear tower
Underside of fuse
