GRT WS EFIS Low Speed Serial Ports
barryrv10
GRT is closed till the new year; does anyone know what is the highest baud rate the low speed serial ports on a WS EFIS can handle. Thanks Barry
Barry,
For my GRT Sport HS EFIS, the max baud rate on the low-speed serial ports was 57,600 (used for the inter-display link).
The fastest rate I see in the manual for WS serial ports 3-6 is 9600 baud. I don't however see a max rate mentioned.
It may depend on whether the WS is a Horizon or Sport.
The Horizon has one or two that go to 115k baud. The rest are limited to 57k baud. I do not know the Sport capabilities.
I checked the spreadsheet I have for my RS-232 plan.
Ports 1 and 2 on the WS H1 are high speed.
However, if you have a plug-in box like ARINC, it uses port 1 and gives you a replacement port but it is a low speed.
Not sure if the GPS plug in does the same. I don't have one.
