I just started working on this myself. The issue I'm having is clearance between the material to be removed and the portions that are to remain. I started trying to drill from the bottom to the top (i.e. from inside the cowling to outside), but there's very little clearance in this direction once the bit passes through the fiberglass. I think it's probably better to drill from outside the cowling towards the inside.
I may pick up a flex shaft attachment for my dremel to see if that makes this process easier.
