BCP Boys
I've purchased a Whirlwind 200RV prop with the Jihostroj Governor - I'm looking for someone that may be able to help with Firewall Forward plans or possibly provide pictures of the firewall forward plans showing the firewall penetration, the governor, bracket, and the oil pressure tube... as well the length of the Blue Prop control cable.
Very specifically I want to make sure that I'm buying the correct parts from Vans.
For example, the Governor Cable Bracket on Vans Website says it's for Harzell or MT Governors so I'm not sure if it will work with the Jihostroj Governor.
I'm sure of all the 7's out there, someone has installed a Whirlwind 200RV prop with the Jihostroj Governor that can help with some pictures or plans. As I said, I want to make sure I order the correct parts.
Thanks in advance for your help.
