A look at the new fuel pump
This is a continuation of my post above, #6. I have received the pump and am posting a picture showing the configuration. Several features are pertinent.
1. Note that the pump comes with the required spacer and O-Ring, so you need not order them seperately.
2. The Rotax Illustrated Parts Catalog says to install the spacer with Loctite 5910 flange sealant. That product comes in a caulking gun size tube for about $45.00! We checked with our local Rotax certified mechanic and found that Loctite 598 can be used. This is available in a .5 oz. tube from McMaster-Carr for less than $5.
3. The vent line and outlet line are 1/4" and the pump inlet line is 5/16" so two sizes of Oetiker clamps are needed. I think I have the correct sizes but won't know for sure until I pull off the old lines to check. Oetikers are marked with size.
4. As mentioned before, you will need to cut off the old clamps and reinstall the fuel lines and firesleeve with new clamps.
These are the tools and clamps needed. Oetiker clamps (pinch clamps) are available from McMaster-Carr and firesleeve clamps are available from Aircraft Spruce.
5. I note that the attached card indicates the fuel pump is set for 4.7 psi at 1600 rpm. I assume that is propeller RPM as the pump is driven off the front of the gear case. My Dynon indicates the old pump regulates at 3.7 to 3.9 psi, however I don't know how well the sensor is calibrated, probably not very well. It will be interesting to see what the new fuel pressure indication will be.
I have an annual condition inspection coming up in a month and will wait to install the new pump at that time.
Tony
