King KY 97a Spikes Ammeter to -20+ amps on transmit
dshevick
Member
I look at the ratings and it should be only 6a on transmit. Any ideas? If I need to get it repaired anyone know of an economical shop? Thanks, David
antenna - coax
Is that into a good antenna? A very poor cable/antenna with a low VSWR could easily cause a higher than usual transmit current.
Find a local radio ham with a VSWR meter to check out your system. :)
Had same problem, solved
by getting rid of coils of excess sensor wires behind the panel. Shortened what I could and moved everything else away form my coax.
Ron
