WingedFrog
I just found that my Skyview does not see the Autopilot servos. I will discuss this with VANs on Monday but just in case somebody experienced this before, please let me know. I have the conversion harness for Skyview.
Do the servos have power? If the autopilot switch is not on, the system can't see the servos.
Have you already done the Network Configuration on page 4-8 of the installation manual?
SETUP MENU > SYSTEM SETUP > NETWORK SETUP > CONFIGURE
Joe Gores
Sounds like you may have forgotten to turn on the autopilot circuit again. Or maybe check the fuse.
[[[[[Don, you can always connect a D10A/D100/D180 to the servos and upgrade the servo software to the latest one for this range of devices. Then connect your skyview back.]]]]
The servo receives + and - voltage for direction movement and talks to SkyView giving position information. Surely SkyView is setup to handle this without "upgrading servo software with a D180".
Am I missing something here?
