Roll servo bracket.
The wing kit includes a W-823 AP bracket to be used in the bottom bracket position on the right wing for mounting an AP servo.
There is a second, small bracket required that is a support brace for the servo (I don't remember the part #, but it is a steel powdercoated part).
It is part of the AP install kit .
Yes you are right Scott, the -10 kit also comes with all the other bits and pieces to complete the install.
The mount bracket supplied by Vans has the added advantage of the molex receiver cut out whereas the Dynon bracket doesn't.
Install looks as easy as the pitch servo.
