Old 04-20-2013, 02:38 PM
PilotBrent PilotBrent is offline
Default Troubleshooting SkyView Audio
Would really appreciate some help troubleshooting my Skyview install in the RV-12.
Section 45A-10/11
I've been adjusting the Control Module per the plans to fine tune the Skyview & audio system. Having a problem with the pilot side audio as follows:
COM. Both passenger side and pilot side appear to be working. Note (when intercom is set to "isolate" the passenger cannot hear his voice in the headset but is able to transmit. I assume this is normal)
Dynon Voice Warnings. Set to 100% per plans. Passenger side has loud, non-distorted volume and appears to be working normally in both ICS and isolate intercom modes. Pilot side works normally with good volume ONLY when the intercom is set to ICS. When it is switched to "isolate", the Dynon voice warnings are very faint (~20% of what the ICS volume appears to be.)
AUX music. Again, passenger side appears to work normally in both intercom modes. However, the pilot side never receives the music at the same volume as the passenger side in ICS mode at all and when switched to isolate, no music at all (this might be appropriate, but the real issue is that in ISC mode the music is very faint)
Not sure if I have a grounding issue with the pilot side and/or an intercom issue. Since the pilot COM seems to work normally in both intercom modes, I'm confused. Where should I be looking??
Appreciate any ideas on why and where to look to fix.
Brent Connelly
Hackettstown, NJ
RV-12, N913BC
http://www.mykitlog.com/brent45
Check out & subscribe to my Youtube channel for latest RV-12 flying videos...
https://www.youtube.com/channel/UCxQ...Px2I7jmazGdLqg
Old 04-20-2013, 03:16 PM
I think you have the pilot and copilot jacks reversed.
When in isolate, the copilot headset should still work normal on the intercom but the pilot headset should be isolated to just the radio.
Old 04-21-2013, 11:17 AM
Default Audio partially resolved.
I confirmed that the RZ441 & 442 wire bundles were going to the correct sides of the fuselage. The molex connectors for each set of jacks had different numbers on them (041222 on left side and 041231 on pilot/right). Could not recall if they were dedicated R/L and plans on 31B-17 didnt help me. So from Scott's note I just reversed them. The pilot and co-pilot sides now are operating logically. Thanks Scott.
Still cannot hear the AUX audio in normal ICS mode however at a normal volume. It's very faint and adjusting the control module to high volume doesn't fix it. Loose wire in one of the plugs?
Still stumped.
Brent Connelly
Hackettstown, NJ
RV-12, N913BC
Old 04-21-2013, 04:27 PM
Dgamble's Avatar
Dgamble Dgamble is offline
Still stumped.
My aux music is very weak unless I pull the patch cord almost completely out of the AUX jack. My working theory (I haven't tested it yet) is that perhaps I am plugging a stereo patch cord into a mono jack and that disjoin is preventing a good connection. I was going to hunt up a stereo-to-mono converter to see if it helped.
Dave Gamble
Grove City, OH
RV-6 N466PG Purchased already flying - SOLD!
Built RV-12
http://www.schmetterlingaviation.com
The above web blogs and any links provided thereto are not instructional or advisory in nature. They merely seek to share my experiences in building and flying Van's RV airplanes.
Old 04-21-2013, 08:29 PM
First: I have the D180, not the SV. However, my aux audio was really poor, and I tried to replace the aux jack at annual. The THREADLOCK defeated me, but in the process of beating the snot out of the aux jack the weak audio fixed itself. Now, if I can just figure out why my GPS496 audio is weak!
Old 04-22-2013, 08:04 AM
Beating on the aux jack probably fixed a bad ground connection.
Have you turned up the volume on the GPS496?
To adjust the volume:
1. Press and quickly release the POWER key.
2. Press the right side of the ROCKER to raise the volume.
3. Press QUIT
Joe Gores
Old 04-22-2013, 09:51 AM
664781 664781 is offline
Default Skyview Audio problem
I have a problem with the side tone being garbled on both sides. Also when I go to isolate on the intercom the pilot side is clipped. I have checked the wiring from both LH/RH jacks to the control module several times and from control module to intercom, all wiring is per plans. Swapped out both radio and intercom with no help.
Working with Vans on chasing wires on the Audio side that is not on the wiring diagram.
Kurt Lohmueller A&P
Powder Springs, Ga
RV6A "Kurt's Toy" - Flying
RV12 - Flying - Sold
Old 04-22-2013, 11:56 AM
Bill_H's Avatar
Bill_H Bill_H is offline
There are more of us than are currently posting having Skyview audio problems. For example, my AOA beeping volume is great, but the voice alerts are very faint, and Dynon confirms these come out premixed on the same wire and without separate volume adjustment. Also I had no luck in my first try at using Halo headsets (that worked fine in an RV8.) So some troubleshooting is beginning. In a week I will be doing the annual and able to get at and check all the wires. My intercom wires were crimped, not soldered and for some other reasons not mentioned here I suspect a loose connection.
Here is some "unorganized data" that I hope to address.
Note that wiring-wise there are at least 4 types of RV-12s:
Type 1: Fully-installed original avionics.
Type 2: Fully installed original avionics then converted to the Skyview using the originally supplied adapter harnesses. (This is like Mitch's and the red factory machine.)
Type 3: RV-12 kits initially assembled with everything BUT the avionics; those of us that were "waiting for Skyview." When the Skyview system for those was originally issued, the supplied "conversion harnesses" did NOT connect up the headsets to the avionics! (It assumed existence of a cable supplied only with the original avionics.) A further harness had to be designed, and the plans revised. This is like mine.
Type 4: RV-12 kits with fuselage and optional wiring harnesses originally designed for Skyview, that do not utilize "conversion harnesses" like the Type 2s or 3s do.
You see, the original conversion harnesses assumed a completed Type 1 RV-12 with the old avionics, like Mitch's. Those RV-12s include a WH-RV12-FLTCOM403 cable that was part of the original avionics install.
That harness included the connection of the headsets to the intercom.
Those of us that "waited for Skyview" did not get (or need) that harness and our headset wires were not connected to anything at the time the Skyview kit was received.
So when the original Skyview system came out, both it and the instructions assumed that other harness existed. An ADAPTER harness was included in the kit for that. But those of us that had "waited for Skyview" had nothing to connect to, and our headset wires were just hanging loose in the panel.
I was the first to report this to Vans (I still have the e-mails) and they quickly came up with the a new, intercom connection harness and instructions for splicing in the headset wires into the Skyview system.
It could be that this problem lies in that setup, because no Vans-owned aircraft has this particular combination installed. They were both full original avionics with the original conversion harnesses. Not the kinda-sorta setup I and several others have. Later RV-12s get all of the harnesses originally made for the Skyview - which for instance have an extra couple of 12V wires going out to near the headset jacks. For example, it could be that the Dynon output is not correctly sent to the AV5000A box.
Also, setting the pots on the av5000 is a bit difficult and many have reported that they are NOT always sent from Vans adjusted mid-range (particularly the trim pot, mine and others were at "zero.")
So more to come... EDITED ADDITION - a fifth type would depend on whether or not you were sent this email by Vans on July 10, 2012 and have done the task or not.
(((((((((((((((Dear RV-12 Skyview owner
We have determined that you may have an early harness manufactured to an obsolete standard, shipped prior to March 2012.
Please check your EFIS harness (WH-00020) to see if it has a wire running from Pin 30 on the 37 pin SVD 1000 EFIS connector to Pin 28 on the 30 pin AV-50000A connector. See drawing 42C-03.
If it does, remove this wire or cut it and heat shrink the ends to break the connection. You can access the connectors quite easily by removing the EFIS screen from the panel. Although this is simply an extra ground wire we have found that it can cause unwanted noise in the audio system, and later harnesses do not have it.
Apologies for the inconvenience.))))))))))))))))
Old 04-22-2013, 12:31 PM
engineerofsorts's Avatar
engineerofsorts engineerofsorts is offline
Default What a relief--I am not alone
I fall in the category of fuse-wired-for-D180-and-got-the-skyview-with-adapter cables. I can't recall all the exact confusion with the headset inputs, except that they were not labeled correctly, either in the drawings or on the wires, so I had to consult Vans to identify things properly. Com and Intercom seem to work just fine, but the EFIS output is uselessly faint--the output level that is selectable from the Skyview DOES change the EFIS output level--100% is very faint, 50% is very very faint. The trimpots on the magical mystery 50000 box for the EFIS input has no effect on volume, just (allegedly) on noise levels from the EFIS. (I don't worry 'bout noise levels when there's barely any signal). All told, sombody ain't playin' the hand they was dealt.
Rob Reese
RV-12 #332
N73HR Now flying!
Austin, TX
Old 04-22-2013, 03:09 PM
Mich,
It's not the 496 volume. Initially the audio worked but got weak and scratchy. Pulling and reinstalling jacks made it work a few hours. There's got to be a loose connection or corrosion somewhere. I'm waiting for my next software update to go in and fix the problem. Access is such a pain I don't go in there unless I really have to. Too bad the design requires canopy removal. Hard to say what I did to the audio jack that made it work, but never look a gift horse in the mouth.
