Old 04-21-2010, 08:00 PM
GAHco's Avatar
GAHco GAHco is offline
Post AN3-58's Best Wishes!
Originally Posted by Phil View Post
Hey Jim,
I'm having a hard time finding a source for AN3-58's, so I'm kinda excited that the bolts didn't make that much difference.
One of the lessons I think I learned in this exercise is that the bolt axis on each side of the pedal are clearly misaligned. This creates binding. I think you could bend them so they are aligned and then use the standard hardware and be fine.
Do you have any photos of your return spring mod? That sounds like a pretty cools option and affordable too.
An AN3-57 is nominally 5 and 7/8" long plus a little for the washer. So the next length is 6 and 0/8ths long, correctly called out as an AN3-60.
The last number in your basic AN bolt never ends in 8 or 9, since the lengths are octal based. Just a lil info.
Get em in the Sky!
Tom Brink Pres.
GENUINE AIRCRAFT HARDWARE Company
www.gen-aircraft-hardware.com
www.gen-aircraft-hardware.com/site_tips.asp
28th Anniversary of GAHco March, 2012
Thanks for being part of our success
Dues Paid November 2012
Old 04-21-2010, 09:09 PM
Phil's Avatar
Phil Phil is offline
Ha! That explains it.
I never thought of that before!
Old 04-21-2010, 09:50 PM
OceanBob OceanBob is offline
Thumbs up I learn something everyday.
Thanks Tom for that reminder lesson......!
Bob
Old 04-22-2010, 12:17 PM
FredMagare FredMagare is offline
Not trying to hi-jack a thread but I had a quick question that's pertinent here: Rather than spend $90 on bolts, would it be feasible to cut an appropriate length from an appropriate diameter rod and cut threads to accept nuts (locknuts or cottered) on both ends? Seems a simple matter to fabricate something more suitable ourselves after all the other stuff we've built.
<standing by...>
Fred Magare
GySgt, USMC (Ret.)
Frederic.magare "at" gmail.com
RV-9A SB Fuselage / Finish Kit Ordered
Old 04-22-2010, 09:00 PM
GAHco's Avatar
Talking Each option has it's cost.
<standing by...>
We are airplane builders, with the right tools and materials we can fix anything. How well depends on skill and materials, and oh yeh, time too.
Somethings I do the long way for the challenge and it beats being at real work.
Other things are great to just install right out of the factory package.
Get em in the Sky!
Tom Brink Pres.
Old 04-23-2010, 10:08 AM
trib trib is offline
Fred,
Read the earlier post on the top of pg 2 for this thread. That's exactly what I did.
Tim Ribble
Virginia Beach
RV-6A (only took 13 years to build )
N621TR In unrestricted operation
Old 04-24-2010, 10:49 AM
Originally Posted by trib View Post
Fred,
Thanks! I should have spent more time reading all the posts. Any problems with your fabrication and setup? Has the brass rod held up well?
Fred Magare
GySgt, USMC (Ret.)
Old 04-24-2010, 07:37 PM
Only 55 hrs on it at this point, but it looks like new
Tim Ribble
Virginia Beach
Old 04-25-2010, 10:54 AM
db8's Avatar
db8 db8 is offline
Default Ref post #10 from Jim in this thread
I am still building a RV-8. I put some half round aluminum brake extensions (like the long bolt idea) on the bottom of my brake pedals. Was wondering if the spring thing would be worth while (or even works) on the 8? Does anybody know by chance? Thanks. Dave
Dave Buntin
http://i55.tinypic.com/iny6qa.jpg RV-8, N 130YS, BOYS & TOYS
[size="1"][color="Blue"]
Old 04-29-2010, 06:54 AM
Airhead Airhead is offline
Thanks Jim, you made it easy. I googled McMaster as you suggested and cut and pasted the part numbers and presto, compiled an order. Total current price $15.90. I think I'll try the springs and then see if I can thread 3/16" brass rod.
Bob B
RV-7A QB slider - IO 360 M1B Hartzell C/S prop w/Dual 10" Dynon Skyviews - Classic Aero interior. 50 hrs TT .
