Old 09-12-2008, 09:56 AM
todehnal todehnal is offline
Default AOA in the RV-12
I know that the Dynon is capable of displaying the "Angle of Attack" indicator. Why in the world would you not use it? Oh well. That's just one more reason that I want to build mine as an EAB.
Anyone else want AOA?
Tom
Old 09-12-2008, 11:26 AM
BrentHumphreys BrentHumphreys is offline
how are you going to get an AOA on there, and still have removable wings?
Brent Humphreys
PPSEL
RV-10 (Starting Empennage )
Status: Elevators
N411BE Reserved
Build Log
Old 09-12-2008, 12:38 PM
Default AOA and wing removal
I don't think that hooking up a couple of pitot lines would complicate the wing removal very much, or for that matter, a few extra wires. The O2 industry has some pretty nice quick connectors that should solve small tubing connection issues nicely. Also, in my case, daily removal of the wings is not a consideration.
Tom
2013- RV12, Kit #119. N123M First flight Nov21. It's a keeper!
1998- RV-9 tail kit, built and sold
1989- RV-6 tail kit, built and sold
Old 09-12-2008, 01:00 PM
Good luck with that.
I can tell you that those connectors do cause a little scoring on the tubing. repeated use on and off over lots of cycles will cause definate leaks.
Brent Humphreys
PPSEL
Status: Elevators
N411BE Reserved
Build Log
Old 09-27-2008, 01:36 AM
Platyius Platyius is offline
Tom
why could you not have the AOA sensor through the prop shaft and spinner I am sure there is enough room for two tubes, does it have to be on the wing??
Tony
Old 09-27-2008, 05:21 AM
RichB RichB is offline
Tony
Odds are the AOA of the wing is not the same as the AOA of the spinner.
Old 09-27-2008, 02:03 PM
E. D. Eliot E. D. Eliot is offline
Cool AOA - RV-12
I agree, the AOA would be useful and not a lot of added trouble to hook up. The connectors (of which ever type) could be replaced as they wear out - not a factor in my mind. How about it, Van's?
Old 09-27-2008, 03:01 PM
Mel's Avatar
Mel Mel is online now
Default Doesn't matter.
The AOA is relative and taken care of in the set up.
A&P/EAA Tech Counselor/Flight Advisor
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 09-27-2008, 04:41 PM
agough277 agough277 is offline
I believe one of the Trutrak autopilots (i.e with the artificial horizon indicator) has a slow warning alarm feature that would act like AOA.
RV6A, RV7, RV6 Wing
Living with my 6A at 3L2 near Las Vegas
Old 03-23-2009, 06:33 PM
Default FlightDEK D180 AOA
It looks like the Dynon FlightDEK D180 is going to be installed in the RV-12. The D180 has the capability to display Angle of Attack using a single combination Pitot - AOA probe that is 3/4 inch in diameter according to the drawing on Dynon's website. http://www.dynonavionics.com/docs/D180_Feature_AOA.html Does anyone know if Van's will be supplying that probe? If not, is it feasible to install it in place of the pitot tube in the spinner? (Assuming EAB or previously certificated E-LSA).
Joe
