Old 04-20-2017, 01:49 PM
Doc922 Doc922 is offline
Thumbs up Dynamic Propeller Balancing in the NW
I have been offering my services for dynamic propeller balancing and vib analysis. I have a Dynavib GX2 (Vib Spectrum Analysis). I have the availability to do a standard dynamic balance as well as perform a detailed spectrum analysis of your airframe or engine. Since I am using the latest Dynavibe GX2, when finished you will see exactly the level of vibrations at start and where they are at the finish. No more guess work. At the conclusion, I can print out a data sheet for you to see graphically the work that was done and a log book sign off.
Statically Balanced is not the same as dynamically balanced. If you have never dynamically balanced your prop or you have not in a long time, you could be causing wearing your engine and airframe.
If in the NW Washington area please contact me at 480-544-2244 or DynamicAeroLlc@yahoo.com A&P/FCC . I am based at KAWO but can travel if needed.
V/R
Larry Pine
Old 04-20-2017, 01:56 PM
ArlingtonRV ArlingtonRV is offline
Larry did my balance last year and did a great job. I am pleased with his work and would recommend him to any needing his service.
Steve Rush
Arlington, WA
ArlingtonRV on YouTube
Glasair Sportsman (Bought disassembled, now flying)
RV-8 Tail, QB Fuselage (Sold)
RV-4 (Bought Flying) (Sold)
RV-9 Tail
RV-12 120018 Flying (Sold)
RV-7 Tail, Wings, Started Fuse (Sold)
Old 04-20-2017, 02:12 PM
1flyingyogi 1flyingyogi is offline
Do you have anyone out West (Southern California) you recommend? Thanks. And does it make a big difference? (static vs. dynamic balancing)
Brian RV4 (bought)
0-320 Carbureted, FP wood prop, Raven 1/2 Oil
Dues Happily Paid
Old 04-21-2017, 02:04 PM
Davedubb's Avatar
Davedubb Davedubb is offline
Default FATPNW Discount?
Are you on the FATPNW Premium list?
Great way to get the word out about your business.
http://fatpnw.org/
donation 2016
Old 04-21-2017, 03:46 PM
Default Thank you
Thank you, I will look into this.
Old 04-21-2017, 03:47 PM
Default Thank you
Thank you for the reference. It was great working with you.
