Old 04-19-2017, 08:50 PM
BHunt BHunt is offline
Default Avidyne 10.2 Software Install
Anyone do this themselves? The "if you brick it, it'll cost ya $1200" warning is making me think twice about it. The problem is finding the time to go to an Avidyne shop, since they seem to only be open during the week.
Scooby
Harrumph!!
RV-8 IO-390 N788MT
Old 04-19-2017, 11:16 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Yes, I've done it - took about 80 minutes, but finished fine.
Put the airplane on external power!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 04-20-2017, 07:56 AM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Easy peasy. Follow the service bulletin instructions and you'll be fine.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 04-20-2017, 08:09 AM
Super Moderator
It's one of the easiest releases to do. It takes a little over an hour, but basically you are sitting there watching it (if you have nothing else to do, as no interactions were required).
Do keep the aircraft on ground power.
Vic
Vic Syracuse
Van's East Coast Representative
www.Baselegaviation.com
Old 04-20-2017, 09:21 AM
24Golf's Avatar
24Golf 24Golf is offline
Where did you find the download?? Did not see it on the Downloads & Docs page for the IFD series...
Paul & Beth Duff
N2724G - RV9A - 900+ Hours
Vans # 91642
FLYING 10.15.2010
BLOG: http://2flyamerica.com/
Old 04-20-2017, 11:39 AM
ChiefPilot's Avatar
Shoot a note to tech support and tell them you're E-AB; they'll get you a download link from there.
Old 04-20-2017, 12:23 PM
24Golf's Avatar
Perfect, THANKS...
Paul & Beth Duff
Vans # 91642
FLYING 10.15.2010
Old 04-20-2017, 12:56 PM
DakotaHawk's Avatar
DakotaHawk DakotaHawk is offline
I did the 10.2 upgrade a few weeks ago. The instructions provided with the upgrade are perfect except... During the entire install process, the instructions are very specific about maintaining power and NOT removing the USB drive. But on Pg 10/step 7, the install is complete, and there is no indication that it is ok to remove the USB drive. Small point, but when you're talking about a $1200 brick fee if the USB drive is removed at the wrong time, it would be nice to know that it's ok to remove the USB drive on step 7.
_______________________________
Scott "Grumpy" Stewart
RV-7 N957RV (First Flight on Dec 18, 2009)
RV-14 N144P (Empennage complete, building wings)
#866 on the Van's RV-7 hobbs
#6563 on Van's generic hobbs
Arlington, WA
Old 04-20-2017, 02:03 PM
Best way for ground power?
Scooby
Harrumph!!
RV-8 IO-390 N788MT
Old 04-20-2017, 02:30 PM
N402RH's Avatar
N402RH N402RH is offline
****NOTE*****
Make sure you have the N number entered into the IFD before you do the update!
10.2 uses the aircraft N Number to unlock a number of features (SVN, WiFi, ...)
and if you don't have the N number in the unit you will lose them.
Rob Hickman
Advanced Flight Systems Inc.
