Old 04-19-2017, 02:46 PM
dirtybirdy80 dirtybirdy80 is offline
Default Wing stand/jig
I ordered my wing kit for my RV-8 a few weeks ago and need to start thinking about building a wing jig or stand to assemble the wing on.
Does anyone have any drawings, sketches, dimensions, etc for building a wing jig they can share with me?
Old 04-19-2017, 03:16 PM
Daida Daida is offline
Default Drawing 12 A top right corner
Put some full swivel wheels under it for easier handling in the shop.
You could have mine, but i doubt it is worth to travel to germany and back!
Cheers!
RV-8 QB Germany
metal work complete
ECi XIO-360 installed
Dynon SV
Wings+Empenage+Fuselage=Plane
Working on glass-thingies
Almost there!
Old 04-19-2017, 03:21 PM
Default Sorry!
First reply is for storing the already built wings!!
As mine were QB, maybe someone else can confirm, but i think for assembly of pre-punched wings you only need a flat table.
Again, cheers!
RV-8 QB Germany
metal work complete
Dynon SV
Almost there!
Old 04-19-2017, 03:32 PM
RV6_flyer's Avatar
Default Drawing 12A for wing stand(s)
Drawing 12A is correct for a "Wing Stand" to build the wings in.
According to the drawing, you need TWO (2) 4 X 4 Vertical posts that is exactly 114" between them. Yes the 114 inches works perfect. My RV-8 left wing is almost complete and ready to come out.
There will be "arms" built out on one side of both 4 X 4s to support the wings. I used galvanized angle with holes in it that I got from Home Depot or Lowe's along with a few bolts / nuts / washers / lock washer.
There is enough info on the Preview / CD / USB plans to construct the holding fixture.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Building RV-8 S/N: 80012
Last edited by RV6_flyer : 04-19-2017 at 03:32 PM. Reason: one side of both 4 X 4's
Old 04-19-2017, 09:05 PM
rapid_ascent rapid_ascent is offline
Look at where the dimensions are referenced to very closely. I put the insides of the posts at the prescribed distance, but you need to take into account the angle piece that the spar sits on. I had to notch my angle pieces because my posts were set too close together. Well and bolted to my garage floor.
Ray Tonks
2018 Donation Paid
RV-7 Fuselage in progress
* Fwd Fuselage Complete
* Mid Fuselage Complete
* Aft Fuselage Complete
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
Shop Setup - In Progress (Gathering Tools, Never Complete)
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
