Old 04-19-2017, 12:17 PM
Toobuilder's Avatar
Question Fuel Tank End Ribs
I’m looking to build a set of tanks for the Rocket and was cruising the Vans site for RV-8 tank end ribs since RV-4 parts are no longer listed. Curiously, there is a T-803-R, but no T-803-L. Is this same part used in both ends of both tanks? I’m thinking the difference is the direction of flanges or embossed stiffeners.
Even curiouser, there is an equivalent R and L for the RV-7 (T-703-R/L). I thought these were essentially the same wing? Additionally, the -7 part is considerably more expensive.
Can anyone shed some light on this mystery?
Michael Robinson
______________
RV-8 - Flying
Old 04-20-2017, 05:55 AM
RogerG RogerG is offline
The RV-4 tank parts are not listed on Vans site, but when I called found them to be in stock, and inexpensive. T-403-R/L for end ribs, and flanges face out. Interior ribs are T-404-L for left wing, T-404-R right wing, and face outboard.
When you call Vans they will gladly email you RV-4-17A Dwg(Fuel Tank)if you request.
Roger Graham
Lubbock TX
RV-4 Under Construction
VAF Dues Paid 2018
Old 04-20-2017, 06:24 AM
N733JJ N733JJ is offline
Default May still be available
I just went through this building new tanks for my 8 with the "old" wing.
As mentioned, there should be a left and a right. Although all models have the "same wing", there are differences in the size of the ribs due to changes of the main spar with different models over the years. If the part is not listed on "the list", it is likely out of stock. Call and ask, in my case a couple parts had to be made so it took a few weeks.
Scott A Jordan
Old 04-20-2017, 08:25 AM
Toobuilder's Avatar
Thank you gentlemen. I'll give Vans a shout tomorrow and hopefully grab some parts.
I am a bit worried about the availability of the earlier parts, as they seem to be selling off and not replenishing. As an example, I needed a new aileron for the Rocket and have to adapt the RV-8 unit. No big deal except for the differences in the spar (the -8 has the big lightening holes, the -4 is solid), and my neighbor snagged the very last -4 spar they had. Fortunately, that's an easy piece to make.
Michael Robinson
______________
RV-8 - Flying
Old 04-20-2017, 01:00 PM
A customer can still order RV-4 kits (Including the wing) so he may have gotten the last one in stock at the moment............
Scott McDaniels
Hubbard, Oregon
Old 04-20-2017, 01:59 PM
Toobuilder's Avatar
OK, that's great. It would be even better if the people on the phone at your end knew that. I was distinctly told (by Vans) that many of the RV-4 parts were being replaced with RV-8 parts, and the -4 stock was NOT being replaced. In addition to my tank ribs, I'll be ordering a -4 aileron spar tomorrow to replace the one in my -8 aileron kit.
Michael Robinson
______________
RV-8 - Flying
