Old 04-19-2017, 08:44 AM
rapid_ascent rapid_ascent is offline
Default Parking Brake Valve Location
I know there is debate about the value of having a parking brake. That discussion is for another thread.
I'm starting to think about the best location for the valve. Some mount it on the firewall in the position of the flex to hardline. I like the idea of moving it up higher on the firewall as others have done to reduce the possibility of hitting the line with your feet, but then the tubing routing isn't as clean due to the diagonal firewall brace.
A third option would be to transition from flex to hardline in the standard location and then locate the valve somewhere between the firewall and the fuel selector valve. I like this idea since it seems the cleanest solution but the control cable would have to be routed further and that may be a complication.
I'm interested ideas and feedback from those who have gone down this path before. I'm sure there are other issues I may not have considered.
Ray Tonks
2018 Donation Paid
RV-7 Fuselage in progress
* Fwd Fuselage Complete
* Mid Fuselage Complete
* Aft Fuselage Complete
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
Shop Setup - In Progress (Gathering Tools, Never Complete)
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 04-19-2017, 11:06 AM
219PB 219PB is offline
I just mounted mine in the standard position on the firewall. I have found that the further I deviate from the plans the time required goes up exponentially. I am enjoying the build but I am itching to go and fly.
Paul Bonorden
RV-6A under construction
My Builders Website
Victoria, TX
2018 Dues Gladly Paid
Old 04-19-2017, 12:34 PM
jmjula's Avatar
jmjula jmjula is offline
I put the parking valve just underneath the upper horizontal longeron and ran hard lines down to the angle bracket Van's has you use to connect to the lines in the floor. I ran flex lines from the value to the peddles. This was a great location for the control cable too as I was able to use the panel rib above to support the cable. I did make sure to locate the hole for the prop cable before running the hard lines... I likely have pictures at home if you need it.
James Jula - CFI/II/MEI - N713JL RV-7A First Flight 10/12/15 - "What is chiefly needed is skill rather than machinery." Wilbur Wright, 1902
Old 04-19-2017, 01:44 PM
N941WR's Avatar
N941WR N941WR is offline
Here is where mine is installed.
(Click to enlarge)
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 04-19-2017, 03:00 PM
VNS VNS is online now
Alternative location for those with long arms
Patrick ZK VNS
RV 9A
Old 04-19-2017, 03:06 PM
Most that we have helped to plumb are located about where Bill has his.
Tom
Tom Swearengen, TS Flightlines LLC
Ridgeland, SC
www.tsflightlines.com
Old 04-19-2017, 03:29 PM
Bevan Bevan is offline
I just removed mine cause I couldn't get it to stop dripping and had little confidence that the new one would be much better.
Bevan
RV7A Flying
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 04-19-2017, 03:37 PM
Deweyclawson Deweyclawson is offline
Default Brake handle location
One of the first things I did when I got my new, 24 year old RV6 home was add a parking brake. The brake handle went in the upper left corner of the instrument panel. I used the cable with the round knob with the push button in the middle. Just pull it out and it stays out. Just push the button in and the handle goes in. I can reach it to release when standing in front of the wing and conveniently just push the button in when putting the plane away.
Dewey Clawson
Super Sabre Society
1993 RV6A, 1947 Cessna 140, in progress
2018 dues exempt but paid anyhow
F100,A7D,A10,F16,
Fokker,Boeing,McDonnell-Douglas
Old 04-19-2017, 05:43 PM
zilik's Avatar
zilik zilik is offline
VAF Moderator
Now why did I not think of that location? The only drawback I see is making sure that it has not been bumped in flight and is ON while landing.
Gary "Seismo" Zilik
Pine Junction, Colorado
RV-6A N99PZ S/N 22993
RV-3B Tail, wings and fuselage.
Old 04-19-2017, 06:03 PM
N941WR's Avatar
That doesn't work for a taildragger because the brake lines go through the firewall, not aft to the spar.
The other issue with putting it in this location on an "A" is it could interfere with the fuel pump, if you have an injected engine.
Bill R.
SC86 - Easley, SC
