Old 04-18-2017, 10:25 PM
togaflyer togaflyer is offline
Default Tank sealant
I need to order some stuff from Spruce, so Im considering ordering tank sealant in the same order. I do not see the tank sealant Van's has offered by Spruce, but Spruce has Pro Seal, some 3m products etc. Is Pro Seal or other products from Spruce good to use, or should I just order the sealant offered at Van's.
Old 04-18-2017, 10:51 PM
I've always bought the least expensive brand which was advertised as meeting the spec, and have never had a problem.
That said, there are some builders with a brand preference.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 04-19-2017, 04:42 AM
rmartingt's Avatar
rmartingt rmartingt is offline
One thing to note is, last time I checked anyway, Van's sells sealant by the quart at about the same price Spruce carries the cheapest sealant by the pint. Something to consider.
RV-7ER - fuselage structure in work
There are two kinds of fool in the world. The first says "this is old, and therefore good"; the second says "this is new, and therefore better".
Old 04-19-2017, 05:59 AM
Tooch Tooch is offline
Default Flamemaster
I just ordered Flamemaster from Sky Geek. Price was better than Aircraft spruce. Have been noticing other thinks better prices from them also.
Old 04-19-2017, 06:08 AM
Check delivery times from Skygeek. I bought some proseal from them a month ago. Showed XX units available. It took 2 weeks or so to ship. and another couple of days for delivery. I'd have had it in 1/2 the time from Van's, or 1/4 of the time from Spruce.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 04-19-2017, 06:21 AM
Walt's Avatar
Walt Walt is offline
I personally won't use anything but PRC Desoto in fuel tanks.
http://www.aircraftspruce.com/catalog/appages/ps890.php
EXP Aircraft Services LLC
RV7A built 2004, 1700+ hrs
Old 04-19-2017, 10:35 AM
az_gila's Avatar
az_gila az_gila is online now
Question
Why would the PRC Desoto product be any better than any of the other ones available that meet the Mil Spec?
"...Meets requirements of specifications AMS-S-8802 formerly MIL-S-8802..."
Is it historic or familiarity since the PRC product was the first one generally available for RV tank construction?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 04-19-2017, 08:55 PM
Thanks for the input. I got my order in.
Old 04-20-2017, 05:59 PM
sglynn's Avatar
sglynn sglynn is offline
Default non-tank ProSeal replacement
For places like in the snorkle around the top to make it air tight is there something besides ProSeal that works great? I'd use ProSeal but I need so little and the shelf life is so short it is expensive to use. What about high temp fire wall sealant like 3M-2000? Can I use it in snorkle around the aluminum parts near the top?
Same question for mounting stuff on or thru the firewall. Does firewall sealant act like an adhesive like ProSeal?
thanks
Steve Lynn
RV-7A
90% Finished
Working on Wiring
Only panel left to go.
Anacortes, WA
www.mykitlog.com/sglynn
Old 04-20-2017, 06:19 PM
Sam Buchanan's Avatar
hall monitor
thanks
Fresh, in-date sealant is certainly the best way to go for sealing RV fuel tanks.
However, "pro-seal" remains a very aggressive adhesive for odd jobs for many years if stored in a refrigerator. I have leftover Pro-Seal (may be Flame Master) in the frig at the hangar that is nearly ten years old and I still use it as an adhesive with excellent results. Using the left-over quart kit has been much more convenient for various glue jobs than buying a new batch every time one of these tasks arise. I used it last summer to seal up some oil leaks on an old O-200 and that engine is practically leak free now.
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
