Old 04-17-2017, 02:24 PM
Jets410 Jets410 is offline
Default RV-10 true useful load w/ real people?
Hi All-
My wife & I are completing the tailcone on our -10 (in the garage, while raising five kids!) and are headed for the QB fuse next. After reading an article about Piper Dakotas, I found myself wondering, "What is the real world useful load on an RV-10 with four real-world adults? Van's website says, "It will carry four FAA standard people, full fuel and sixty pounds of baggage.", then states, "accommodates four full-sized adults."
Useful load = 1070 (2700 Gross -1630 BEW)
I figure 4 full-sized adults = 900 lbs.
Leaving 170 left for fuel = 28 gallons = two hours w/o reserve.
That's ok when flying our friends one hour to the beach for dinner, fueling, and coming home, using a Lycoming IO-540 at 14 gph (rough high-end estimates from what I see on these boards).
So the question is, are there some more actual numbers RV-10 fliers would like to share on the heavy side? Does anyone carry four linebackers and still have enough gas to fly more than an hour? Is my data incorrect?
Thanks, -Scott
Old 04-17-2017, 02:42 PM
Carl Froehlich's Avatar
Four real people (two men, two women), full full and the baggage compartment filled to the top. Flew to Key West from Virginia on a hot day. No problem (other than dogging the afternoon Florida thunderstorms).
Disclaimer - if you fatten up your RV with Lexus interior, air conditioning and such you will not enjoy such performace. My plane has a full glass panel, a heavy base/clear coat paint job, O2 and a heavier cowl and plenum. Empty weight is 1685.
Old 04-17-2017, 02:44 PM
Auburntsts's Avatar
Well yeah. Van's uses the FAA standard of 170lbs per pax not the 225 you used. I weigh 190 and my wife weighs 150 so I typically get full fuel and a little baggage with 4 adults. But the useful load is a zero sum game--if you and your pax weigh more then something has to give, and partial fuel is the only card you have to play. This is not unique to the RV-10--a lot if 4-place planes are really only 2-place in practical terms.
As for fuel planning I typically cruise at 11 gph which gives me 160 TAS so leaning out will give you a bit more endurance/range.
Todd Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 04-17-2017, 02:45 PM
Carl,
What gross weight did you use for your airplane?
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 04-17-2017, 04:30 PM
jwilbur jwilbur is offline
Originally Posted by Auburntsts View Post
.... my wife weighs 150 ....
You are so gonna be in the dog house. .....
-Joe Wilbur (N520LW)
Phase II - 11/2017
First flight - 8/2017
Pink slip - 7/2017
RV-10 Build Log
Old 04-17-2017, 04:38 PM
Auburntsts's Avatar
Nah....I've learned the art of pre-emotive apologies. IOW, money can't buy happiness but it can buy flowers, massages, jewelry, etc. seems to work...
Todd Stovall
PP ASEL-IA
WAR EAGLE!
Old 04-17-2017, 04:57 PM
I think I'm a real person even though I'm not a linebacker!
My -10 is light- BEW = 1607 lbs. No ac, no fancy paint, Basic interior. I even gained a pound or two of useful load by swapping out my gtx-327 for a Trig TT22. Every pound adds up. My wife and I together (note how I hide her weight!) are just a bit over FAA standard at 350 lbs which leaves 380 lbs for another couple and bags, with full fuel. Not linebackers but maybe punt returners! BTW, I flow matched my injectors and routinely cruise at 160 KTAS on 10 gal/hr, so even with your load I'd have 2 hours PLUS an hour reserve.
Old 04-17-2017, 05:07 PM
Mike S Mike S is online now
Default Its a truck
What the others have said----it holds a lot.
Not yet mentioned yet, but something you need to pay attention to is how the C/G acts when loaded heavy. As you burn off fuel, the C/G can go out of range to the rear
Always figure your C/G at take off and landing fuel loads to be safe.
Old 04-18-2017, 01:41 AM
paul330 paul330 is offline
Mine weighs in at 1650lb which I think is pretty average. So with full fuel load I can get 4 reasonable (not Texas!) size adults.....
My problem comes if I reduce the fuel to 2/3rd load to get 100lb of baggage as well. Then I run into C of G issues. I have a lighter MT prop plus a strobe pack, ELT and ADHARS behind the baggage bulkhead. Next time my battery needs replacing, I'm going to go with an Earth-X, save myself 15lb and shift the C of G forward significantly.
Paul
Mercy Air, White River FAWV
ZU-IIZ - "Zeus"
2017 Donation Made
Old 04-18-2017, 05:24 AM
Flying again!'s Avatar
Flying again! Flying again! is offline
CDC says the average US male weighs 199.5 and female weighs 166.2. With you useful load this leaves 346.6 lbs for fuel and baggage.
I took my wife and adult son and daughter to the Bahamas and had full fuel plus 100 lbs of baggage. I did swap out my battery for a Li Iron battery to keep CG within limits. I allocated 20 lbs baggage per person to have room for safety items (life vest, PLB, etc.).
Worked out great for a week trip!
As others have said, everything is a trade-off.
RV-10 N331JH 3rd owner (First flew in 2005, #15 flying)
Northwest Regional 52F
