Old 04-14-2017, 11:19 AM
FlyGood FlyGood is offline
Default Brake Line and Horizontal Tail Questions
Two questions for the RV-8 brain trust:
For the interior flexible brake lines, I used Aeroquip 306 hose on the recommendation of a local parts shop. Now it's time to install the exterior lines from the bottom of the Grove gear to the calipers and I want to make sure. Is 306 hose suitable for brake/hydraulic fluid? If not, what is a good choice for flexible brake lines?
Second subject: I've read numerous posts about elevator authority during landing with a forward cg. Has anyone considered/tried vortex generators on the underside of the Horizontal Tail?
Thanks for any help and advice!
Taco
Ken Cockrell
RV-8 Fuselage Slow-Build In-work; on gear
Tail Kit complete
Wings In-work
N247TM Reserved
Old 04-14-2017, 09:44 PM
Carlos151's Avatar
Carlos151 Carlos151 is offline
If I remember correctly the VA-102 fuel pressure hose that Van's sells works great for the Grove gear brake line. Nice braided hose with no modifications needed.
Karl Richcreek
RV-8
N151TK "La Otra Chica"
Flying as of August 14, 2015
Old 04-15-2017, 09:09 AM
ILikePike ILikePike is offline
That's what I used.
Jeff Green
2016 RV-8 #82985
1968 E33C Aerobatic Bonanza
Pleased to donate Dec 2017
Old 04-15-2017, 09:32 AM
DanH's Avatar
DanH DanH is offline
I've read it, but mine will 3-point at 79".
Dan Horton
RV-8 SS
Barrett IO-390
Old 04-15-2017, 04:57 PM
Default Thanks
Copy all. I'll go with the stock Van's lines for the external lines.
Doesn't sound like vortex generators are needed on the tail. I may experiment anyway.
Thanks, all!
Ken Cockrell
Tail Kit complete
Wings In-work
N247TM Reserved
