Old 04-12-2017, 04:32 PM
JDA_BTR JDA_BTR is offline
Default GTR 20 and GTX 45R
Can we collect some pics of where we mounted these? I'm trying to work out where all the behind the panel items will go.
N1463 seems a good number....
Old 04-12-2017, 08:58 PM
KeithB KeithB is offline
See some pics on post #18
http://www.vansairforce.com/communit...e+boxes&page=2
Keith Brown
RV-14A Builder - kit #136
N314KC - First flight Mar 8, 2017, >270 hrs
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 11/2017
Old 04-13-2017, 02:00 PM
M McGraw's Avatar
M McGraw M McGraw is offline
Default RV14 Garmin G3X equipment
Hello,
The first two pictures are the pilot side. (2) GTR20s and a GAD29. The standoffs are to allow for air movement.
The second two pictures are the co-pilot side. Transponder, Audio Panel and EIS. This allowed me to remove the Transponder through the Canopy opening. Note it is mounted at a slight angle.
The GDL39R and GAD27 are mounted on the back side of the same subpanel.
Important note: I am a first time builder, so this information is worth exactly what you paid!
Marvin McGraw, 5TN4
RV-14. #140039 Complete
Flight hours: 150+
2018 Dues Paid
Old 04-13-2017, 09:23 PM
Very good, I had a similar sandwich of components in mind.... Any pics of the structure you built to make the sandwiches?
Old 04-13-2017, 10:05 PM
M McGraw's Avatar
Default Sandwiches
I don't have pictures of the individual brackets; however, it is basically long AN bolts and aluminum tubing to create the space between components. Some of the brackets are simply cut and bent 2024 sheet. I used 1/4" between components for air circulation; however, I have no data to suggest that is necessary. It merely seemed like a good idea at the time.
Marvin McGraw, 5TN4
Flight hours: 150+
2018 Dues Paid
Old 04-14-2017, 05:48 AM
Walt's Avatar
Walt Walt is offline
Haven't done a 14 yet but I've mounted the transponder behind the baggage wall on a number of RV7's, works well and keeps the antenna cable short which is important for the xpdr.
EXP Aircraft Services LLC
RV7A built 2004, 1700+ hrs
