Old 04-14-2017, 06:21 AM
Jesse's Avatar
Jesse Jesse is offline
Originally Posted by Deweyclawson View Post
Call it a Jeffwhip-10. Put that on the registration and A/W cert. The tax man has no way to question the value as you are the manufacturer. Give it a serial number in accordance with the manufacturer's (you) numbering policy. Your first build, label it serial number 1.
JMHO
Then see how your insurance quote works out with an unknown "one-off" design Jeffwhip-10. Would also hurt resale value I would assume.
352-427-0285
jesse@saintaviation.com
Old 04-14-2017, 09:26 AM
Raymo's Avatar
Raymo Raymo is offline
Originally Posted by carolsyracuse View Post
Ray
Don't mean to burst your bubble, but GA has a property tax on aircraft. Perhaps they haven't found you yet probably since you flew after the first of the year. Early in the year they send out a questionnaire. If you have your aircraft in a corporation they may very well find you if you are at a public airport. The airport managers report tail numbers. In which case you will be charged a use tax.
Here is a previous thread discussing this:
http://www.vansairforce.com/communit...t=property+tax
Bubble bursted!
I had been keeping the plane in SC but will be moving it to GA soon. I guess they'll get me... hopefully later
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
Old 04-15-2017, 09:45 AM
Snowflake's Avatar
And the FAA may require a 51% determination for the kit for your "one-off" design as well.
Rob Prior
Old 04-15-2017, 09:44 PM
pilotkms pilotkms is offline
Default Possible tax credit in Georgia
Do some reading at dor.ga.gov. I found this easily "a taxpayer's use tax liability will be reduced by like taxes previously paid in another state. "
they may have another clause that negates it but I couldn't find it, yet. I have heard that some states do not allow this and u get to pay twice. Maybe other victims can add info about their state.
Keith
RV 7A. RV #9700
Built in SoCal KCCB
N325KS
Phase 1 Completed Nov 2017
Old 04-16-2017, 04:25 AM
Deweyclawson Deweyclawson is offline
I was simply quoting from the paperwork for my RV6A.
Make: Townsend
Model: RV-6A
Serial No.: 001
About half the RVs I looked at were labeled this way.
Dewey Clawson
Super Sabre Society
1993 RV6A, 1947 Cessna 140, in progress
2018 dues exempt but paid anyhow
F100,A7D,A10,F16,
Fokker,Boeing,McDonnell-Douglas
Old 04-25-2017, 06:16 AM
Nukeflyboy Nukeflyboy is offline
Default TX Tax Bad Info
There are some misconceptions about the Texas tax passed here.
If you buy an existing (flying) aircraft, you can usually avoid sales tax since it is a "casual buy". Not so from a dealer. Texas also has a "use tax".
If you BUILD an aircraft, it is subject to a use tax. The fact that you bought kit parts somewhere else is not relevent. If its first flight is in TX, or if you bring it into the state within one year of its first flight you are subject to the tax. Once you register it you will likely be contacted by the tax office. The tax is not cheap.
They have a publication that covers this and you should check it out because it is complicated.
A bunch of guys will chime in and say they never paid the tax. For some reason the tax office ignores RV4-7, but pick on RV-10s. Probably some $ cutoff. Life is not fair.
I paid this tax on my 10, not on my 6.
Dave Moore
Granbury, TX
RV-10 and Breezy
Old 04-25-2017, 07:11 AM
Mel's Avatar
Mel Mel is offline
The insurance on my A&M-6 is exactly the same as it would be on an RV-6. As a matter of fact insurance has it listed as "A&M-6/RV-6"
Serial # is 92006. Ann & Mel's 6th build and we thought it would be finished in 1992.
A&P/EAA Tech Counselor/Flight Advisor
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 04-25-2017, 07:17 AM
Mel's Avatar
Mel Mel is offline
FAA WILL require a 51% determination!
"Amateur-Built Fabrication and Assembly Checklist (2011)"
North Texas (8TA5)
FRIEND of the RV-1
Eagle's Nest Mentor
