Old 04-09-2017, 11:50 AM
E. D. Eliot E. D. Eliot is offline
Default Yaw damper for 12?
Noticed that Dynon has announced an update that includes software inclusion for a yaw damper. Don't know the details as to how it would apply to RV-12 set up. Looks like this improvement may require some additional metal work, etc, in order to work.
Just wondering if this would be a good idea for installation into the 12? If so, how do we get the bracketing, etc? Will Van's make a kit? Obviously, I have no idea as to what would be required but I am very interested.
Your thoughts---
Building finally
Old 04-09-2017, 11:52 PM
gossend gossend is offline
Not needed. The 12 is quite stable in yaw. I wouldn't bother, but what do others think?
Dick Gossen
gossend@gmail.com
Flying: EAB RV-12 with G3x Touch
Old 04-10-2017, 12:01 AM
DHeal DHeal is online now
IMHO, not needed. Also, you would need to have a closed-loop rudder cable system and/or an active rudder trim tab??
I have found that by keeping one's feet on the rudder pedals during cruise (as opposed to being flat-footed on the floor) the yaw tendency is reduced.
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 600+ hours (as of Feb 2018)!
VAF donation through June 2018.
Old 04-10-2017, 04:00 AM
Piper J3 Piper J3 is online now
The 12 "dances" in yaw quite a bit when flown in turbulence. I don't know what aspect of the design causes this but its prevalent.
Hinckley, Ohio
P/ASEL 1970 Sport Pilot since '04
RV-12 E-LSA #120058 AWC 7/12 Bought Flying 10/15 with 48TT - Hobbs now 317
LSRM-A Certificate 2016
Old 04-10-2017, 04:27 AM
KALEWIS's Avatar
KALEWIS KALEWIS is offline
Talking
Because of the short wheel base of course !!!!
Airspeed, Altitude, or Brains...you need at least two
RV-12 #328
At 260 Hrs on the Hobbs
http://unicom12.blogspot.com/
Click on above for build site
Old 04-10-2017, 05:19 AM
rgmwa rgmwa is offline
I find the RV-12 quite comfortable in turbulence. Maybe it's the seating position, but I seldom feel that I'm being bounced around much. It's more like the plane is moving in all three axes around me. Can't see any need for a yaw damper.
rgmwa
120346
Old 04-10-2017, 05:20 PM
flightlogic's Avatar
flightlogic flightlogic is offline
I instructed an airline pilot one time for a tail dragger add on. He had forgotten thirty years ago what his feet were for. And he had size 14 shoes. That was a challenge. In the 12... just use your feet to tame any yaw. You will appreciate the calm days... and have less hardware to maintain.
Now, altitude hold.... different story.
"Kindness is never a bad plan."
Old 04-11-2017, 10:33 PM
In turbulence on auto pilot I rest my feet on the rudder pedals which eliminates the tendency to hunt in yaw.
